Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-04-2018, 11:20 PM   #6761
mlatter's Avatar
Originally Posted by LegacyFB38 View Post
And a third...how tough is it to re-install the hitch when removed like that?
Just make sure the truck is straight in front of the trailer, and lower it back into the holes. It's maybe 50% more of a pain than regular hitching, so really no big deal.
When I winterize it here in Canada, the hitch always dangles from the trailer. Saves space in the garage!
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
mlatter is offline   Reply With Quote
Old 10-04-2018, 11:37 PM   #6762
Kaadk's Avatar
Originally Posted by mlatter View Post
I do it all the time with mine. I hate having it in the bed of the truck if I'm not towing. I have the underbed mounting system so when it's out, nothing but 4 holes are showing.
I use a ratchet strap to keep the back of the hitch up and level so it pulls out and goes back in easily.
You got a picture of it? I’m not sure how to keep the hitch body from rotating.
Old 10-05-2018, 11:43 AM   #6763
mlatter's Avatar
I don't have a picture that shows it clearly enough right now, and the hitch is in the truck at the moment, since we're hooking and unhooking a lot with weekend trips.
I just use a ratchet strap that goes between the locations shown by the arrows on the diagrams (generic pictures downloaded from the Internet). It just hooks on the back of the slot on the hitch and goes up and hooks on the back of the pin box. I ratchet it quite tight before I raise the trailer to lift the hitch out of the truck. The strap serves to lift the back of the hitch to keep it level, and also to prevent it from swinging.
ID:	188326   Click image for larger version
Old 10-05-2018, 05:25 PM   #6764
RusLwt001's Avatar
KOA HOLLY MICHIGAN. Just pulled in. When you really, really want to upgrade to a 5th Wheel. Click image for larger version
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
RusLwt001 is offline   Reply With Quote
Old 10-05-2018, 07:03 PM   #6765
Does Dollywood count?Click image for larger version
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 10-05-2018, 07:28 PM   #6766
[QUOTE=mlatter;1943226]I do it all the time with mine. I hate having it in the bed of the truck if I'm not towing. I have the underbed mounting system so when it's out, nothing but 4 holes are showing.]
I have the BW slider and leave it on the pin sometimes, but it sure makes the landing gear groan going up with the extra weight.
9.5 year old FR Cherokee 295 WP 32' toyhauler
2013 Ford F250 SD CC 4X4 4.30 gears
Tuned-- engine, music, and exhaust,
bpadamson is offline   Reply With Quote
Old 10-05-2018, 10:14 PM   #6767
mlatter's Avatar
I figure with around 2500lbs pin weight, another ~250lbs for the hitch won't matter much. No different than me walking into the bedroom really.
Old 10-06-2018, 01:41 AM   #6768
Always Learning
2 things:
1) I don't think I could do that with my AutoSlide.
2) I thought you were happy with your Andersen. Why'd you switch back?
2) I did like it. It’s a great hitch and I feel it’s a safe hitch. BUT- the combination of my trailer, the fixed pin box, and my truck- our ride was just really rough. My wife deals with back pain and it just exacerbated her pain. We needed to switch to an air ride hitch or pin box. I went all-in with the air ride hitch.
Honestly not bad with 2 people, though I think the ratchet idea is excellent. I sat in the truck bed and talked her back to where it was mostly lined up. We got it so that it aligned on top of the rails, lowered + unhitched it from the camper, and dropped it in place.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 10-06-2018, 01:43 AM   #6769
Always Learning
I checked with the hitch manufacturer and they said it was fine.
As for the landing gear, I agree- 3,200 lbs pin weight. Another 250 for the hitch is nothing.
Old 10-06-2018, 09:24 PM   #6770
twohand's Avatar
Seeing this right now...Click image for larger version
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: ‘18 - 27, ‘19 - 27, ‘20 - 30, ‘21 - 49
twohand is offline   Reply With Quote
Old 10-06-2018, 09:28 PM   #6771
robbiels7's Avatar
Originally Posted by twohand View Post
Seeing this right now...Attachment 188454
I have seen one before somewhere
robbiels7 is offline   Reply With Quote
Old 10-07-2018, 08:59 AM   #6772
Georgia Rally Coordinator
aceinspp's Avatar
Jayco and GR Endueance tires
Saw this yesterday in our cg. Brand new Jayco tt with GY Endurance tires which came on the camper. If Thor can do why not FR. Later RJD
ID:	188467   Click image for larger version
ID:	188468   Click image for larger version
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-6 days
Old 10-07-2018, 09:46 AM   #6773
They could, but likely won't.
Old 10-07-2018, 09:55 AM   #6774
Casey & Carolyn
Casey r's Avatar
I do it all the time. Sometimes you get lucky and they all 4 line up. Sometimes I lower it in to the bed and release it in the bed pull forward move it around with a pry bar until they drop into the holes lock it down the back under the 5 th wheel.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
Old 10-07-2018, 10:40 AM   #6775
Canadian Member
Goodyear Endurance hasn’t been available for a good long time so it can’t necessarily be deemed a great tire yet but so far we aren’t hearing of any problems with the brand so they are looking good. That said, Jayco is likely installing the Goodyears as a marketing thing as much as for the quality of tire.
Assuming they are indeed a good quality tire, they aren’t the only good ST tire available in the market. Not every tire made in Asia is a “China Bomb”.
All I would want is that they install a quality brand tire with a Load Range appropriate for the GVWR of the trailer.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 10-07-2018, 12:12 PM   #6776
Same could be said for the Castle Rocks yet they (FR) chose to install them. It's all about whatever is least expensive and has nothing to do with quality. Jayco may be using it as a marketing strategy but I'd bet it will work for them.
Old 10-07-2018, 12:37 PM   #6777
The Endurance is getting positive comments, even though it's only been out, what, 18 months? Of course, it's going to be 3 or 4 years before we'll know if they're as good as said. Until the, I recommend Sailuns.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 10-07-2018, 05:04 PM   #6778
aceinspp's Avatar
I'd say good strategy. I've had mine now for 16 months and love em. Now get Mr Buffet to buy in Later RJD
Days camped 2019 62
Old 10-07-2018, 05:19 PM   #6779
Lance comes standard with Endurance as well. I put them on both my Lances and love(d) them. Have them on a couple other trailers at work too.
WY Husker Fan is offline   Reply With Quote
Old 10-07-2018, 05:45 PM   #6780
No pic and this was on the way to the RV Park; class C passed us on I-95 dragging the black tank on the pavement. Now I have to wash the truck.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
