Old 01-21-2022, 09:25 AM   #9061
Originally Posted by NavyLCDR View Post
Why? I was merely pointing out that if the ground was not level, the trailer was actually level, and the camera was parallel to the ground (not level), it would give the optical illusion that the ground was level and trailer was not. However, given the relation between both trailers and the fence behind the power pedestal, it is very safe to assume that neither trailer is level. In my previous trailer it would not cause me to roll out of bed, but rather would place my feet above my head.
Why the geez?... My mission with the post wasn't to fool anyone with optical illusions of camera angles nor show my ineptness at being able to hold a camera/phone level. Obviously you couldn't take it as such.
If you look at the photo from the rear, there is a wooden fence around the breaker box for that row of sites. The fence boards are vertical. The slide on the R/V in question is nowhere near parallel with the boards and my entire reason for including that shot. There's also a permanent building in the background you could have referenced if you chose to.
It seems the link for the front shot no longer works, I'll try to repost.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 01-21-2022, 09:26 AM   #9062
Originally Posted by DougW View Post
Pure speculation here, is it possible they don’t know how to adjust the legs on the steps so they park like that to be able to open the door?
Something I hadn't thought of... you could be right.
Old 01-21-2022, 09:31 AM   #9063
Or their doc said elevate your head to help with acid reflects
_______________
2020 Plat F350 diesel DRW
2021 Riverstone Legacy 37mre
filthy-Beast is offline   Reply With Quote
Old 01-21-2022, 09:38 AM   #9064
Mr. Dan's Avatar
… and/or “acid reflux”.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 40; Booked for 2022 = 70
Old 01-21-2022, 09:41 AM   #9065
Mr. Dan's Avatar
Maybe the owners of the RV camp purposely erected the wooden fence on a slant to make owners of adjoining trailers dizzy.
Old 01-21-2022, 09:41 AM   #9066
Darn spell check again!
_______________
Old 01-21-2022, 09:43 AM   #9067
Maybe the un-levelness gives the the correct angle of the sun to reflect the reflux?
Old 01-21-2022, 09:44 AM   #9068
Mr. Dan's Avatar
You’d be surprised at what people blame on spell check as if spell check altered a word AFTER they hit submit.
Old 01-21-2022, 09:46 AM   #9069
No wonder the world seems off kilter!
Old 01-21-2022, 10:06 AM   #9070
llr
Or possibly dropped off too much, I was somewhere that I needed to use a platform step to set the legs on as the legs would not reach the ground.
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 01-21-2022, 10:14 AM   #9071
sdelam's Avatar
My steps are a weird height, Factory fold out was a two step that seemed really high and were not the same height between the two. Replaced it with a 3 step fold in the door set up but it barely works on level ground. I use a couple of 2x12 to raise the trailer even on flat ground to make sure the door will close. However, I raise both sides equally.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 01-21-2022, 02:29 PM   #9072
rracer5's Avatar
Maybe his flux capacitor needs to be at an angle in order to alleviate the acid reflux.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-23-2022, 11:11 AM   #9073
I do it all the time because I rarely proof read and I use Swype to 'type' so I don't always get the word I wanted but the one the phone thinks I wanted
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 01-23-2022, 11:37 AM   #9074
Yes, it happens to all of use.
Edit: I meant us.
NavyLCDR is offline   Reply With Quote
Old 01-23-2022, 11:43 AM   #9075
I wonder if they (and their off kilter neighbor) are hoping on opening a tourist attraction? Something like this:
http://www.oregonvortex.com/
Old 01-23-2022, 02:27 PM   #9076
Quite possible!
We have some places like that here in PA.
Gravity Hill, where you drive halfway up the hill, put your vehicle in neutral and it will roll UPHILL!
I think DougW hit the nail on the head though with the steps/door wouldn't open idea.
They've moved to what the park refers to as a luxury site this morning with a blacktop pad and paver patio.
The R/V is level now.
I'll have to try and get a photo. (or maybe not!)
Old 01-23-2022, 02:33 PM   #9077
Quite possible!
I was wondering if maybe the inside of their trailer was built that far off level from the frame, and they were level on the inside!
Old 01-23-2022, 02:43 PM   #9078
Professional a/c install
0rion100 is offline   Reply With Quote
Old 01-23-2022, 02:46 PM   #9079
I did the same to our first two Coleman pop--ups we had.
Actually worked quite well.
Old 01-23-2022, 05:01 PM   #9080
rmac04401's Avatar
Neither camper in original picture took in consideration the effect of the slide when out on being level. It’s level before slide is in but dips due to slide out. My brother has Three slides and he says he has to level with one bubble up to account for dip once the slide is out.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2011 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
