Old 08-05-2022, 01:41 PM   #1
Tire Inflator/Air Compressor Recommendation
Hi All!
Looking for a recommended portable air compressor/tire inflator, both for my camper and SUV tires. I want one that will power from both the "cigarette" port in the car, as well as regular plug-in. I want it to inflate fairly quickly, not be too noisy, fill up to 65 psi, have a display, stop inflating at the set psi, not be too heavy, and priced $50-$100.
Any suggestions are greatly appreciated!
msveggie is offline   Reply With Quote
Old 08-05-2022, 01:59 PM   #2
Typically they are mode for 1 power source or the other not both. You are demanding a lot of features at a low price point. The standard which people generally compare to for portable inflation is Viar. I don't think you can get one of their compressors for $100.
Also if you are plugged in to shore power you could power a 12v inflator from the trailer and the shore power would keep the battery charged.
-2017 Isata 5 35DB (bunkhouse)
#teambunkhouse
Phreak480 is offline   Reply With Quote
Old 08-05-2022, 02:42 PM   #3
I bought the Viair 450P-RV. Power cord has alligator clips for the battery. Nice unit but not cheap.
Sunseeker16 is offline   Reply With Quote
Old 08-05-2022, 02:42 PM   #4
Mr. Dan's Avatar
Thatís Viair if youíre doing a search. Let us know if you find something close to your specifications for under $100.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 109; Booked for 2022 = 14
Old 08-05-2022, 03:54 PM   #5
OYO
OYO's Avatar
+1. Viars work great!
Why worry about 120v? You're always going to have 12v on your tow vehicle or camper.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Home is where you rAise the roof.
Craig
OYO is offline   Reply With Quote
Old 08-05-2022, 03:56 PM   #6
borrowed a neighbors and was impressed
20 volt dewalt
attach small hose to tire valve .. no have to hold it
set the pressure you want to inflate to
took about a minute to check each tires pressure and to add 10 pounds
It had a second screen that showed actual pressure of the tire
cost closer to 200.00 with a battery
https://www.homedepot.com/p/DEWALT-2...B&gclsrc=aw.ds
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-05-2022, 04:09 PM   #7
We bought this one and it works well for the truck and van tires on our rigs.
TIREWELL 12V Tire Inflator-Heavy Duty Double Cylinders Direct Drive Metal Pump 150PSI, Compressor with Battery Clamp and 5M Extension Air Hose, SUVs/Trucks/Vans/RVs https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The only thing it won't do is shut off automatically. When it gets to the proper inflation, you turn off the switch.
It's not going to work on a full size motorhome though.
For a longer reach
to plug into ac this
edit....Ooops reversed the links
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-06-2022, 02:24 PM   #8
KOBALT from Lowes meets your requirement and works for me.
oneandone is offline   Reply With Quote
Old 08-06-2022, 04:44 PM   #9
Virginian's Avatar
ÖÖ
Iíve been using this same one for 2 years and itís worked fine for me.
Tops off my truck and trailer tires just fine when needed.
Virginian is offline   Reply With Quote
Old 08-06-2022, 05:00 PM   #10
GravelRider's Avatar
If you're using it for your camper and tow vehicle, I wouldn't bother with 120 V. You'll always have 12 V DC available. And if you happen to only have 120 V receptacles in your camper, you can always get a 120 V AC to 12 V DC adapter for cheap on Amazon.
I have this one from Walmart, which has been working quite well for me through several flats.
https://www.walmart.com/ip/Slime-Mul...8?athbdg=L1200
If I were traveling somewhere truly remote, I'd either have a backup, or buy something a bit better/more expensive.
GravelRider is offline   Reply With Quote
Old 08-06-2022, 05:17 PM   #11
Nice unit
That's a nice looking unit, and the price isn't bad. Not sure if I would buy an extension cord for it. Instead I would simply add a second curly hose to extend the reach. This one adds 25 feet for $16. I wouldn't use fancy couplersbbb--just permanently thread the two hoses together.
My thinking is that the longer the motor power cord, the harder it is on the motor. Adding air hose avoids this.
Larry
Larry-NC is offline   Reply With Quote
Old 08-06-2022, 05:42 PM   #12
bob213's Avatar
I would be afraid to run one of those inflators off my cigarette lighter. The only way I would use one is with an adapter straight off the battery with a long air hose NOT power cord.
https://www.autozone.com/test-scan-a...B&gclsrc=aw.ds
That's just me and I admit I'm a worry-wart
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is offline   Reply With Quote
Old 08-06-2022, 05:50 PM   #13
That's true, however we have a kind of unique need to power our tire inflator off ac. The small mh is stored in a garage type enclosure. Running the engine to inflate the tires fills the garage with fumes.
The garage has electric, so hooking the inflator up to an ac to dc converter with a cigarette lighter port allows us to top off the tires without getting overcome with fumes. We could pull the rig out of the garage, but it is a storage lot so sometimes doing that would conflict with others because we'd be blocking about 3/4 of the driveway.
Old 08-06-2022, 09:51 PM   #14
MillMitch's Avatar
For a longer reach
I looked at those, but they are only rated to 35psi per the description. Do you use yours to 50/60 psi?
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 08-06-2022, 09:55 PM   #15
MillMitch's Avatar
Never mind, that 35psi reference was for a 2 min fill time on small tire
Mitch in MN
Old 08-07-2022, 03:59 AM   #16
FrankG's Avatar
Costco has been selling the CAT branded portable power with a air compressor for under $90.00. Handy, compressor works well.
2021 F-150 XLT with most of the goodies
2021 Surveyor Legend 19RBLE
2018 Haulin 6 x 12 Cargo Trailer by Forest River
2017 Laredo 325RL Sold
2016 Vengeance 29V Sold
1970 Yellowstone Used as downpayment for first house
FrankG is offline   Reply With Quote
Old 08-07-2022, 06:46 AM   #17
WV Ridge Runner
I've had the Air Hawk for approx 5 yrs and liked it but just went bad on me. I recently purchased the below air compressor from Amazon and I really like it. Doesn't feel cheap, the display showing psi is nice and I think it goes up to 100-120 psi. Have it under the back seat of my truck. Has been really handy, rechargeable battery and still plugs into the cigarette lighter.
https://www.amazon.com/dp/B0948WY5YX...t_details&th=1
2022 Forest River Wildwood X-lite Midwest 273QBXL TT
2021 Ram 2500 Bighorn CCSB Cummins (Granite Metallic)
Camco R6 Recurve WDH
Timbrens Rear Suspension Enhancement
kmartin25404 is offline   Reply With Quote
Old 08-07-2022, 06:46 AM   #18
Originally Posted by msveggie View Post
Hi All!
Another Viair recommendtion.
https://www.viaircorp.com/
I wished Iíd gone camping sooner in life.
Traveling Circus is offline   Reply With Quote
Old 08-08-2022, 06:12 AM   #19
Thanks to all!
Thank you everyone, once again, for your quick suggestions and insights. I appreciate it all.
Old 08-08-2022, 06:45 AM   #20
Your motorhome when plugged in to 120v power is an AC to DC converter. That's what the power converter in an RV does, and it has the house battery to help it buffer very high amp draws.
#teambunkhouse
tire
