Old 04-16-2013, 10:31 AM   #21
mjones12's Avatar
I don't know what brand of black tank flusher came with my trailer from the factory, but I'm wondering if excessive water pressure is a concern when using it. Naturally, I would not use the same pressure regulator or hose that is used for fresh water, but I just wondered if the plumbing for the flush system would stand up okay to unregulated pressure.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-16-2013, 12:06 PM   #22
Always Learning
Good question because I actually branch my water off at the campground spigot and don't restrict the water to the flush.
Old 04-16-2013, 03:10 PM   #23
Herk7769's Avatar
Since the end is open, the pressure would never be as high as in a closed system.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-16-2013, 03:21 PM   #24
PPST OGCDG
Frank-VA's Avatar
We had one installed when we purchase our Wildcat 29RLBS. It works great. A whole better than draging the hose into the camper!
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 04-16-2013, 04:36 PM   #25
mjones12's Avatar
Thanks, Lou. One more thing I can quit worrying about. I appreciated your input, as always.
Old 04-16-2013, 05:03 PM   #26
Cool
We have a 92 Carriage Cashey 2600 and I started to install one on our black tank. According to the instructions I was to drill a hole on the far side away from the drain. Well this was not going to work since the tank was about 4 inches from the frame and I had no tools that would fit. So to the local RV shop I went. They said no problem. Right..they just found a convenient spot and drilled away. It seems to work ok because the water flows but not sure of the spray pattern in the tank.
Wildkats66 is offline   Reply With Quote
