Old 06-06-2020, 12:56 PM   #1
Travel Trailer Dolly
I'd like to get some input on the usefulness of a trailer dolly. I have a 3100 lb Apex Nano. Flat driveway that I would like to be able to turn my TT without towing it thru my yard each time I leave on a trip. Any input would be appreciated.
Thank you,
cus105
Ford F150 2020
Honda Pilot 2011
Apex Nano 3100lbs
cus105 is offline   Reply With Quote
Old 06-06-2020, 01:14 PM   #2
OYO
OYO's Avatar
I use a Trailer Valet on my A-frame (~4k) and boat (~5k). It works pretty well on flat paved surfaces. Takes a little getting used to.
It works better if you can attach it to the toung rather than on the aframe of the trailer. On my camper the toung is too short.
I don't recommend one for a dual axle trailer. There is too much tire friction to turn it much.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Home is where you rAise the roof.
Craig
OYO is offline   Reply With Quote
Old 06-06-2020, 04:58 PM   #3
I use this to move a utility trailer, one steers while the other pushes.
Your Nano is relatively light.
https://www.harborfreight.com/600-lb...lly-60533.html
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-06-2020, 06:25 PM   #4
GLBCamper's Avatar
+1. I do use it on a dual axle 4000lb TT, it does work, but it MUST be level and paved. But I can get it in a very tight space and it’s better than paying storage fees.
2021 Cherokee Alpha Wolf 23rd TT
2016 F150 4x4 Sport
GLBCamper is offline   Reply With Quote
Old 06-06-2020, 06:44 PM   #5
OYO
OYO's Avatar
Yep. I have a tight fit for our boat in the garage. I can literally drop the toung jack on a dime every time with little effort.
Craig
Old 06-26-2020, 01:53 PM   #6
+1 on the Trailer Valet. Works very well on single axle trailers, a bit tougher on dual axles but still doable. On smooth level surfaces, like the floor of my very large shop, I also find it pretty convenient to just set the front jack stand pad on a metal four wheeler (I.e., Harbor Freight’s auto wheel dolly) and then just push the trailer around. This works for both single and dual axle trailers. For very heavy trailers, I use a Power Caster good for up to 18k pounds. Couldn’t live without it.
ProfessorBB is offline   Reply With Quote
trailer, travel, travel trailer
