I lived in a 1995 Terry for 6 months while my house was being built. I went through the winter of 1995/1996 in Denver and one morning I looked out to see my little thermometer show -15 degrees. The water lines were all run inside the heated space and I had to add a tank heating pad to my gray and black water tanks.
Keep the water tank filled and if you don't have a Black/Gray tank heater pour a pound of Rock Salt down the drains/toilet. The salt will keep the water from freezing unless you have a really deep freeze.
You need to make sure you have plenty of propane. The local propane supplier dropped a 250 gallon tank in front of my trailer and made an extension hose to my regulator. Some days the furnace never shut off and there was a solid coat of ice down the sides of the trailer where snow on the roof had melted and re-froze as it dribbled down the side.
That trailer and the new Flagstaff Micro-Lite I took delivery of 3 weeks ago are night and day when it comes to insulation. The Micro-Lite came with tank heaters that run on both 120VAC or 12VDC.
FWIW, these heater pads can be added to existing tanks if one desires to do some cold weather camping and doesn't want to wait until spring to empty the holding tanks
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
