Old 09-06-2020, 06:15 PM   #1
Water streaks
Just washed and used protect all on the beast. I’ve got these streaks that won’t seem to come off. A little history: Just bought this 2019 used Coachman Freelander 31BH. Seems a little early in its life to have permanent staining. Not sure why the pictures are sideways sorry.
ID:	238530   Click image for larger version
ID:	238531   Click image for larger version
ID:	238532   Click image for larger version
Iceman0987 is offline   Reply With Quote
Old 09-06-2020, 06:22 PM   #2
Chris Pastuzyn's Avatar
Welcome from New Jersey, pictures didn't show streaks, There are cleaners that are primarily designed for streaks,
Chris Pastuzyn is offline   Reply With Quote
Old 09-06-2020, 06:59 PM   #3
Thanks I revised the pictures! Michigan here, Starting to get colder here �� how’s Jersey?
Old 09-06-2020, 07:35 PM   #4
Ahhhhhh now I see them, Weather is low 80's low humidity, I think its supposed to be like that all week, Have you tried ant cleaners? I know the boating people have stuff to remove black streaks, Check West Marine,
Old 09-06-2020, 07:46 PM   #5
I’ll check some marine stores thanks, it’s crazy to think that something has etched its way into the gel coat on a 2019.
Old 09-07-2020, 07:42 AM   #6
HappilyLost's Avatar
Meguiars boat and rv products are what I use. Safe on all fiberglass and gel coat surfaces. Their oxidation and gel coat restorers are great products. Use those, soap and wash, and wipe it down with a water spot remover and it should be good as new.
HappilyLost is offline   Reply With Quote
Old 09-07-2020, 07:52 AM   #7
Thanks I’ll try it out
Old 09-08-2020, 05:36 AM   #8
Witch Doctor's Avatar
I agree with the water spot remover, it works well, are you sure that’s just not run off from your roof, that will create that also, keep a good wax on it and you should be alright.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-08-2020, 05:40 AM   #9
Dawn Dish soap. Used it since 2008
TheWolfPaq82 is offline   Reply With Quote
Old 09-09-2020, 06:28 AM   #10
Hopefully you didn't put protectant over streaks, if so you will have to remove it first
loyda is offline   Reply With Quote
water
