Old 03-14-2022, 11:37 PM   #21
Originally Posted by ARhappycamper View Post
What is a "wet bay".
The wet bay is the area in the basement where all the water connections to the RV are. City water, black tank flush, outside shower connection. On many models this area is isolated from the rest of the basement by walls so as it will contain any water spillage.
2016 Siverback 33IK, Towed 50K+ mile2018 Ford F-350 Lariat 6.7L V8 Diesel 4WD Crew Cab
Old 03-15-2022, 08:44 AM   #22
Trailer Park Supervisor
NJKris's Avatar
Wet bay is where your water filter and all those hoses comes together from pump, city water are, especially in an unheated exterior accessible compartment. It's susceptible to freeze damage and must be monitored/drained/or protected with a heat source (I use a tiny Sharper Image thermostat controlled heater.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 03-15-2022, 10:18 AM   #23
It's the compartment with the waterworks - fill valve, outdoor shower, filter, etc. It's the first area that would freeze on my rig.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
tinkerreknit is offline   Reply With Quote
Old 03-15-2022, 10:28 AM   #24
D W
D W's Avatar
That's a fancy term for "plumbing connections".
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 03-16-2022, 02:13 AM   #25
Camping the Natural State
Never heard it called a wet bay before and also didn't know campers have basements. Have owned campers 40 years. Thanks
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 03-16-2022, 11:11 AM   #26
Being only concerned about temps I use a LaCrosse unit with 3 remote sensors. I put 1 on top of one of the tires out of the rain for ext temp, 1 in the fridge and 1 in the cooler used for drinks.
2020 Flagstaff Micro Lite 22FBS
Old 03-16-2022, 12:24 PM   #27
D W
D W's Avatar
We have a cheap ($29), Acurite System that provides date/time, indoor/outdoor temps and relative humidity respectively. We don't profess to be meteorologists. For weather updates such as storms/wildfires we use our FRS & GMRS radios set to the NOAA channel.
2016 Salem 27RKSS
Old 03-16-2022, 06:35 PM   #28
larry2c's Avatar
I have an Ambient weather station at home and love it. However, like others mentioned I don't want to hassle with setting something like that up for camping so I just have an old ThermoPro (antique version of what RedRover showed). It lives in the drawer until we're set up then the main unit goes on the "entertainment center" cabinet top and the remote unit goes under some shade on our little roll up table outside. It satisfies my weather junky fix
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 03-21-2022, 06:27 PM   #29
strut526's Avatar
Our local news/weather stations usually offer a discount on weather alert radios. In Michigan, it's getting to be tornado/ spring storm season.
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 03-21-2022, 07:48 PM   #30
Iíve had several weather stations from different companies over the years and Iíve found Acurite or Lacrosse as good as any, contrary to what some are saying on here.
Also Acurite can be calibrated, at least the ones I bought.
They have to be checked periodically and corrected.
Unless you buy a professional one and pay many more dollars than I want to pay, my last one was 280.00 CDN.
I donít really want to know the weather that accurately, having said that, my last Acurite is right more often than the weatherman, probably doesnít surprise most people!
My motorhome has a Lacrosse unit with sensor on rear ladder
Celticrider is offline   Reply With Quote
Old 03-21-2022, 09:29 PM   #31
I have an Accurite and for the winter I put the remote sensor in the basement the farthest point away from the heated area. This also happens to be where they ran the H/C lines for the washer hookup. Make sure the temp stays up in that far corner.
My wet bay is right next to the H/W heater and then next to that is the furnace.
I cut a length of R11 fiberglass insulation the full height of the bay. Then just keep it right at the opening of the door so all the water lines are behind it.
This winter when pulling the dump handles you could feel the warm air behind that insulation. So, no worries.
FirstFiver is offline   Reply With Quote
Old 03-21-2022, 11:00 PM   #32
Originally Posted by Littoral Adventures View Post
If you have one, where do you place your external sensor?
I lay it on top of a tire under the slide-out, there it's outside but protected from rain, direct sunlight or other things that might damage it or give a false reading, ....
fella10 is offline   Reply With Quote
Old 03-22-2022, 12:10 AM   #33
jkoenig24
I put my outside sensor IN the wet bay compartment. On winter afternoons, I monitor that sensor and if the temp dips below ~ 36F, I switch on a drop light that has a 100W old school incandescent bulb. Said bulb provides enough heat to prevent freezing in the wet bay.
jkoenig24 is offline   Reply With Quote
Old 03-22-2022, 01:33 AM   #34
Sharon455's Avatar
Pretty sure we have an Accurite. Keep the remote sensor in the shallow bay above the propane tank.
Checked it a few times after first getting it and the temps were always within 1į-2į of being outside the passenger door.
Happiness is just a ride away!
Sharon455 is online now   Reply With Quote
Old 03-22-2022, 08:28 AM   #35
We bought this one here and I love it. I put the sensor on the picnic table and when we pack up I remember to take it then. https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
2018 Flagstaff 29KSWS 2016 BigHorn Dodge Ram 1500
Blue Ox Sway pro weight Distribution Hitch
mbanovetz is offline   Reply With Quote
Old 03-22-2022, 04:05 PM   #36
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Many motor homes, TTís and 5th wheels have a plastic lined compartment outside the rig that houses all the domestic water connections and may include a shower connection.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 03-22-2022, 08:29 PM   #37
Platokidd's Avatar
For me this weather stations stuff is an addiction. Have stations at Work, home and at camp. Ambient (ws-2000 / ws-2902a) and prefer the big brother Ecowitt (HP2552) that can use any Fine Offset sensors.
Can also keep an eye on my beer temp while away.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 03-24-2022, 10:50 PM   #38
I have two mounting methods for my outdoor temp, humidity and windspeed head. Both involve the same 8' piece of 3/4" metallic electrical conduit. (Taller would be better but 8' fits in the basement storage area.)
Method 1) clamp my "custom" plywood template (board with a 3/4" hole near one end of it) to a campsite fence rail if available or to one corner of the campsite picnic table and slide the pole through the hole to anchor the middle. Drive a round wooden stake into the ground in line with the hole in the plywood and slip the conduit over it to anchor the bottom. Adjust the position of the plywood as needed so the pole is vertical. Done.
Method 2) If method 1 doesn't work for lack of a fence or picnic table (or the ground is all paved around the picnic table and there's no way to drive in my wooden stake) slide the metallic conduit pole into the slightly larger rigid plastic conduit I've "permanently" fastened to one side of the roof access ladder with two stainless steel plastic-pipe clamps. (Poor man's flag buddy knockoff) I prefer method 1 because method 2 involves having to climb the ladder to insert and remove the metallic conduit. Been using this for seven years. Almost idiot proof unless I fall off the ladder some day.
2015 Wildcat Maxx 28' pushing a 2020 F350 6.7L
GFD47 is offline   Reply With Quote
Old 03-24-2022, 11:46 PM   #39
Originally Posted by NJKris View Post
Exactly why I didn't want to mute alerts, every once in while they are useful, but 9 times out of 10 some dummy reports a car on the grass. Super annoying. It's like maniacs are out there punching the 'report' button every mile.
I think of those "vehicle on shoulder" reports as potentially meaning "activity on shoulder". I wish they would report which side so that I could proactively change lanes away from pedestrians, tow truck drivers, aid vehicles, etc
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 03-25-2022, 08:27 AM   #40
NJKris's Avatar
I'm impressed somebody knows about the "move over" laws most states have! I just drove I-80 from NJ to Ohio and back, it amazed me how many drivers completely disregarded this, even with plenty of room to change lanes and good forward view to see the disabled or stopped vehicle on the shoulder.
door
