Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-01-2020, 09:56 AM   #1
What generator to buy
Can anyone advise me on the best alternate power supply? Generator or Inverter generator. My DW and I are soon to become full timers. The model 39FKTH 5th wheeler didn't come with a generator
stannwen
2020 Riverstone 39FKTH
2018 Silverado 3500HD 4x4 Curt 24K hitch TST 507
Rostra camera on truck Furrion on 5th wheel
2014 Harley Davidson Triglide
stannwen is offline   Reply With Quote
Old 05-01-2020, 11:54 AM   #2
Trailer Park Supervisor
NJKris's Avatar
stan, type generator into search bar. More advice than you can possibly read in a rabbit's lifetime. But short answer, inverter generator.
Yes, I drink the water!
NJKris is online now   Reply With Quote
Old 05-01-2020, 11:58 AM   #3
Short answer, "Inverter Generators" are quieter than regular generators. Also consume less fuel as they usually have an "Eco mode" that allows the engine to run at lower speed when load is low.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-01-2020, 12:02 PM   #4
Definitely inverter generator. A trailer that size may be 50 amp, so you'll need a good size generator for that, but avoid the open-frame contractor types. They're way too loud.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 6 Speed 3.42
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 05-01-2020, 02:22 PM   #5
bikendan's Avatar
Yep, there are literally hundreds of threads on what generator to buy, on the Forum.
You want an INVERTER generator, not a regular generator.
Decide what you want to run and where.
Add up the power needs to determine what size inverter generator you'll need.
Old 05-01-2020, 02:34 PM   #6
If you want to use the generator for powering your R/V anywhere except your own property or on private land where no one will be close to you, you need an INVERTER generator.
If you want to use it in a campground type setting (State/National Park, COE, etc.) the Parks all have decibel rating limits that would prohibit the non-inverter generators (often called contractor type) from being used as these non-inverter generators make too much noise.
As for best or which is better a generator, as mentioned, there are literally hundreds of past discussions on this topic with many opinionated posts. It is one of the most asked questions on this forum.
If on a computer, just go towards the top of the page and in the green bar click on the word search. (which is between New Posts and Quick Links)
Type in: inverter generator and hit go.
You'll get lots of reading.
Read up and decide what is best for YOU.
I see you have 2 posts... welcome.
Please come back and ask any questions you've not found answers for.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 05-01-2020, 02:36 PM   #7
NMWildcat's Avatar
Inverter generator. You can get one large one (3400+), or two smaller ones (2000+), if you intend to run the A/C.
If you want to run a nurse tank (extended run tank), a generator with a fuel pump is much easier. Most will not have one. Honda's do
As far as which brand, depends on your budget. My first choice will always be Honda. Mine are 13 years old.
Next in line is Yamaha, then Champion. After Champion, as far as I'm concerned, it doesn't matter what you pick. Last on my list would be Predator.
Good luck and Happy Camping!
Scott and Liz - Southern NM
Old 05-01-2020, 02:44 PM   #8
are you going to be 'off-grid', without any 120v shore power, for extended lengths of time, more than a day or so at the time? Will you actually 'need' one?
If you're going from rv park to rv park, probably not.
The Turners...
formerFR is offline   Reply With Quote
Old 05-02-2020, 02:34 PM   #9
"Curmudgeon"
Send a message via MSN to Trawlerphil Send a message via Yahoo to Trawlerphil
"Shorter answer--Predator 3500 watt inverter generator"
TrawlerPhil
2014 Flagstaff Classic Ultralite 8528RKWS
2018 F-150 4X4 Max tow EcoBoost 3.5
2020 Tesla Model Y
Trawlerphil is offline   Reply With Quote
Old 05-02-2020, 02:59 PM   #10
bikendan's Avatar
I would agree, for a trailer like that. Best bang for the buck.
Old 05-02-2020, 03:00 PM   #11
I presently have the Westinghouse inverter 4500, which I like, it’s quiet. I choose to use gasoline as my fuel. I had a Honda before that which was great also, but twice the price.
The 4500 will run your A/C no problem and more, however I have 2 A/C’s and had to install soft starts on the A/C units to run both.
It will run all night no problem, I just leave it in the pickup when using and have had no issues, just my .02.
JimEisley is offline   Reply With Quote
Old 05-02-2020, 03:18 PM   #12
You may want to consider a duel fuel inverter type. It will run for a long time on a 30 lb propane tank but doesn’t smell of gasoline if you store it in the RV basement storage compartment when travelling.
Just my $.02 worth.
Clyde M is offline   Reply With Quote
Old 05-02-2020, 04:12 PM   #13
Generator
Inverter for sure. Depending on what you want to spend, and if you are looking for a 5 Th. wheel, you may want to have a Rv generator installed in your front hatch. Any of the 3500-4500 watt inverter are over 100 lb. dry, 3 gallons of gas and minimum 124 lb. Taking my Generac IQ 3500 (more metal and insulation Predator) in and out of my F-350 is a 2 person or front loader job. You also have to ensure you have clearance w/ pin box. Not sure of all the features, but I would look at the new Echo 2400 generator, 75 lb. They are linkable and about $750 each. If I did it again, I would consider 2 of these. I have heard them run, very quiet. Just something other than a Honda to look at. I have had Hondas and Yamahas, prefer the Honda as engine is larger. At the ballon festival last year, our neighbor had a 3500 Honda, tone was lower but same volume as mine. His was 133 lb. dry, almost 160 lb. w/ fuel-heavy. He had a ramp, but in the sand a struggle, I helped.
Tundra 2014 is offline   Reply With Quote
Old 05-02-2020, 04:17 PM   #14
Generator
If you look @ a dual fuel, realize you lose power on propane. Also consider the power lose at altitude. 3% per 1K altitude approx., and I may be off a percent.
Old 05-02-2020, 04:52 PM   #15
frank4711's Avatar
Yes ... quiet and runs all I need for stop overs when going to campgrounds farther away ...
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 05-02-2020, 05:01 PM   #16
The "Food Trucks" around here all use the Predator brand. The trucks run them all day, every day, all season.
In addition to "inverter" remember generators are heavy. The Honda EU2200i weighs 48 pounds empty. Add 4 gallons of fuel and you are lugging 80 pounds.
Years ago I had a 3500Watt Generac inverter generator. It was an external frame generator and the quietest available. It weighed 98 pounds empty and 130 pounds with fuel. I carried 2 of them. I was also 45 years old. Today I would go with two 'paired' generators instead of one larger generator just to avoid the weight.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 05-02-2020, 05:20 PM   #17
Generator
Good looking rear rack.
Old 05-02-2020, 07:40 PM   #18
2019 Renegade Verona LE
Just saw the new Onan Inverter
I just saw the new Onan 4500/3500 inverter. This is the same technology as the one in most motorhomes. I would check this out. I have never had any problems with any of the Onan generators I have owned over the last 35 years.
CaboSnow is offline   Reply With Quote
Old 05-02-2020, 07:59 PM   #19
bikendan's Avatar
Are the Onan generators in motorhomes, made in China?
Because that inverter generator is made in China, as is its twin Westinghouse 4500/3500 inverter generator.
https://cdn.shopify.com/s/files/1/00...g?v=1550179975
The Westinghouse name has sold to various companies, mostly overseas:
"Since 1998, Westinghouse Licensing has*licensed*the famous*brand*for use on a multitude of products, some of which were in similar categories to those sold by the historic version of the company. Though these products advertise the Westinghouse name, they are not manufactured by the historic Westinghouse company".
Old 05-02-2020, 08:59 PM   #20
I recently bought the Champion 3500 gasoline inverter version WITH remote control....I really like using the remote control. I have only run it nearly 6 hrs and did the break-in oil change. I installed an engine run meter which is nice. Lastly and most importantly, it runs my 15K AC unit....didn't seem to have much problem in a short test. Oh, I also got lucky and got it at half price!
Hopefully, I will get many years of use.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
