Old 09-12-2022, 09:50 PM   #61
The way I use mine
I put a spray head on it and clean the litter box with it
maxxtc is offline   Reply With Quote
Old 09-12-2022, 10:34 PM   #62
I enjoyed reading your reply’s to your outdoor shower use, although some I rather not visualize,🤣. However, I do have a FYI comment - check to make sure that the shower head itself is in the “off” position and definitely double check that each hot/cold water faucet is off too. We learned the hard way and place the shower head in a plastic bucket while we travel just in case it accidentally is manipulated while on the road.
Nikerin is offline   Reply With Quote
Old 09-13-2022, 12:04 AM   #63
Midwest Ed
Shower outside and save on the grey water tank.
2017 F150 XLT 5.0L 8ft bed
2015 Coachman Freedom Express 192RBS
Midwest Ed is offline   Reply With Quote
Old 09-13-2022, 01:56 AM   #64
distracto's Avatar
Originally Posted by Baumeister View Post
We do still need to figure out the mat situation, we've resorted to a pallet, or anything available.
We use this:
https://www.ikea.com/ca/en/p/runnen-...gray-90238111/
clicks together quickly, is light, and transports easily.
2021 Freedom Express 257BHS Mod Thread
2021 Coachmen Freedom Express 257BHS
2019 Ford F150 Super Crew 3.5 Eco Boost Max Tow Package
distracto is online now   Reply With Quote
Old 09-13-2022, 08:35 AM   #65
Originally Posted by Rhumblefish View Post
Anyone have a dedicated shower pad or mat that they use under their outdoor shower? We currently don't use it much – save for occasionally rinsing off the feet – but it might be nice to take a nature boy shower when equipped with enough privacy.
Our last trailer had the outside shower at the rear and it was always used in National Forest campgrounds so the back was always in our campsite. We had a foldable wooden (teak) shower grate for the ground and I made a PVC pipe frame for a curtain rod. I hung a small tarp as a curtain with shower curtain rings and the frame was supported with two adjustable legs. I made aluminum brackets that mounted to the trailer that the frame attached to via hair pin cotter pins. This made it so we could dry camp for 9 days without filling the gray tank.
If you're pouring, it's half full.
If you're drinking, it's half empty.
Eric H. is offline   Reply With Quote
Old 09-13-2022, 08:48 AM   #66
We simply turn our pump off and relieve the pressure on the system when traveling.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 09-13-2022, 10:00 AM   #67
We set up a outside kitchen sink and just connect the hose there to do all the dishes. Gray tank doesn't get full so quick that way.
Flagstaff 5th Wheel 529BH 36'
Ram 3500, dually, cummins
lannieoakley is offline   Reply With Quote
Old 09-15-2022, 07:12 AM   #68
Wheres the Imagination..... REALLY
Originally Posted by PoppySteve View Post
There is a locking compartment door on the outside wall of my RV with hot and cold water, water hose and a nice shower head inside. The word
"SHOWER" is molded into the door. I see a lot of them on various RV brands.
Seems like RV manufacturers are providing a way to shower outdoors.
Sure might be better than trying to fit in some of the dinky inside showers.
It says what it is.....
dill is offline   Reply With Quote
Old 09-21-2022, 09:31 PM   #69
aufinger's Avatar
On my previous campers, I used the outdoor shower to wash the pots and pans. On my present camper, it also has an outside spicket with a garden hose nozzle that I now use to clean things up outside. With the spicket, I'll probably never use the outdoor shower. I'm surprised that my camper has both in that they both basically do the same thing.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
aufinger is offline   Reply With Quote
show, shower
