Old 05-07-2015, 07:44 PM   #1
What size floor jack?
We just picked up our rockwood 8327ss. What size floor jack do we need to carry?
sharkbate is offline   Reply With Quote
Old 05-07-2015, 07:52 PM   #2
Timex's Avatar
Well, you just picked it up so you should know!
Seriously, I'm curious myself.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-07-2015, 07:53 PM   #3
Hardy harhar.
Old 05-07-2015, 07:59 PM   #4
Don't Jack it Ramp it! Easy! Youroo!!
Old 05-07-2015, 07:59 PM   #5
Dazed & Confused
M&K Hoffman's Avatar
I carry one of these: Trailer Aid Tandem Tire Changing Ramp
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 05-07-2015, 08:02 PM   #6
HONDAMAN174's Avatar
I use a trailer aid plus also. Just be sure to practice at home first as I found out that I still needed to put some Legos down to get tire off ground.
Just glad to get away
Old 05-07-2015, 08:04 PM   #7
Timex's Avatar
Hardy harhar.
I couldn't help myself!
Old 05-07-2015, 08:54 PM   #8
I carry the Trailer Aid and a 12 ton bottle jack, but no floor jack; you don't jack up your camper on the axles, only the frame.
Sirsea is offline   Reply With Quote
Old 05-07-2015, 09:12 PM   #9
Stormrider151's Avatar
I have a 3.5 ton floor jack that has a sticker on it that say's "not for use on RV's". Why? I have no clue. I sure would like to know though.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-08-2015, 03:56 PM   #10
Hmmmm. The check out guy specified floor over can.
Old 05-08-2015, 04:10 PM   #11
A lot of floor jacks will not fit between the tires to get to the place to lift between the axles and lifting on the axles is a big NO-NO!
Old 05-08-2015, 04:33 PM   #12
67cudafb's Avatar
Why is putting jack under the axle a big no no
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
Old 05-08-2015, 04:38 PM   #13
They bend/deform VERY easily! Just don't do it!
Old 05-08-2015, 04:41 PM   #14
Because you can bendeded the camber or tweak your axles out of alignment. Frame only or tire ramps.
Trailer aid plus, legos, and two 4ton bottle jack stand combo jobs here. But my rig doesn't weigh as much as your Rockwood.
rana is offline   Reply With Quote
Old 05-08-2015, 05:04 PM   #15
jevanb's Avatar
I put a 10 ton bottle jack under the spring outer-most u bolt, works for me and is only a few inches from the tire so IMO no axle deformation or tweaking, no way I could get a jack under the frame as the skirt is in the way and it is a long way up to the frame from ground level
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-08-2015, 05:10 PM   #16
+1 that's how I do it also.
steveh326 is offline   Reply With Quote
Old 05-08-2015, 05:20 PM   #17
Those of us with torsion axles can't do it but still have to reach the suspension framework. I just made an adaptor for my bottle jack and it works great.
ID:	76456   Click image for larger version
Old 05-08-2015, 05:53 PM   #18
Timex's Avatar
I have to almost crawl under the TT to put my bottle jack in position but taking the tire off isn't a fun job for an old, fay guy anyways!
Put mine on the frame above the axle and blocks under the axle.
I think I need to find another place for the blocks though. They're only there in case the jack fails.
ID:	76458   Click image for larger version
Old 05-08-2015, 07:17 PM   #19
kcjoe1's Avatar
I can do the ramp or I carry a 6 Ton bottle jack for the just in case thing.
2017 Arctic Fox 27-5L
2014 Rockwood 8289WS Diamond Package (SOLD)
2008 Dodge Ram 2500 SLT 4X4, Anarchy Tuning
kcjoe1 is offline   Reply With Quote
Old 05-08-2015, 07:50 PM   #20
gashog's Avatar
I carry a 6 ton bottle jack and the Andersen Rapid Jack. I have no ideal if the Rapid Jack will work with the torsion axles and Dexter said not to use them. The 6 ton bottle jack works great. I place my bottle jack between the tires identical to the way OldCoot's is showing in his pic. I use blocks to get the height, but now I need to copy OldCoot's and his extension. Glad I got the smaller 6 ton cause it's a tight squeeze getting past the tires. I ended up getting my bottle jack at Walmart, I like the fact it came with a hard case. Placing the bottle jack between the tires lifts both tires off the ground. My only gripe is the jacking handle needs to be longer (I scrape my knuckles on the tires while jacking) , but that an easy fabrication to make a longer handle.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
