Old 07-27-2021, 12:57 AM   #1
what tripod stabilizer do you use.
Waiting on my Rockwood 2883ws to be built but would like to purchase a few items before unit is delivered to dealer. I'm looking for advise and suggestions for a tripod stabilizer jack.
Relder is offline   Reply With Quote
Old 07-27-2021, 09:47 AM   #2
Always Learning
I use the BAL Fulltimer FastJack:
https://balrvproducts.com/products/c...n-tripod.shtml
Really though, the SteadyFast stabilizers do a better job and isn't something that you have to put up and take down at each setup. But they're a harder/actual install.
https://learntorv.com/product-review...t-stabilizers/
Old 07-27-2021, 09:53 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
I had one that I used on my 2nd 5th wheel and personally I did not see any improvement for stability. My new 5er is very stable and do not use any type of system. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-40 days
aceinspp is online now   Reply With Quote
Old 07-27-2021, 10:17 AM   #4
X2
I had one that really didn't do much good.
I've since put on JT Strongarms triangular stabilization and have quit hauling around that heavy king pin jack.
Days Camped: '18=48 '19=58 '20=110 '21=116 '22=112 '23=83
Old 07-27-2021, 12:31 PM   #5
Good advice from all.
With the remarks I've received I plan on making a few trips without any stabilizing system to see if this 5'er is stable enough without any extra support. Otherwise, I will go with a JT Strong type system.
Old 07-27-2021, 12:46 PM   #6
Movement in an R/V is inevitable. It's a mobile platform on a sprung frame. Some folks are more susceptible to the movement than others.
I've said this before but I'll say it again... I love my DW but she walks like an elephant and can bounce through the R/V like a herd of them.
I started with a tripod king pin jack with no difference. it wasn't supporting or suppressing movement where it mattered most, in the living area. I then added x-chocks and that helped a good bit. Then I added screw scissor jacks at the axle and that helped even more. Finally I've added the JT Strongarms and that's eliminated about 98% of our movement.
Old 07-27-2021, 12:48 PM   #7
NMWildcat's Avatar
Yep, everyone used to have a kingpin stabilizer tripod. I think we were victims of marketing. Now, you rarely see them, and there is a reason. They don't do much of anything, PITA to setup and store. Everyone in my group chucked them years ago.
Steadyfast or strongarms work well. Another option is to use your RV so much that eventually you won't even notice the movement
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-27-2021, 01:41 PM   #8
I bought one 12 years ago for my first 5th wheel. After the first trip I stuck it in my garage where it still sits. The bulk of the weight in a fifth wheel when parked sits on the trailer's suspension and is stabilized by the front jacks and rear stabilizers, or the auto levelers. There will always be slight movement since the suspension in most trailers involves springs and by definition, springs, um, spring.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 07-27-2021, 02:04 PM   #9
Springs or Spring!
The 2883ws has the torsion flex axles, no springs, so wonder if that will make a difference in movement?
Old 07-27-2021, 02:12 PM   #10
Our 8509IKBS has torsion axles.
It doesn't seem to move any more or any less than our others that had spring suspensions when stationary. Interior movement is something you'll fight on any towed R/V regardless of how it is sprung (springs or torsion) unless you put it on blocks/pillars.
Old 07-27-2021, 02:14 PM   #11
If you have kids and you and your partner want to use the forward bedroom then they might be an advantage. Otherwise I don't see a need.
eaglecrest is offline   Reply With Quote
Old 07-27-2021, 02:51 PM   #12
Always Learning
I fulltimed for 5 years... when do I stop noticing the movement?!
Old 07-27-2021, 03:39 PM   #13
NMWildcat's Avatar
LOL! But then you had the whole family in there with you It's only my wife and I and she isn't big enough to shake anything. During the last trip we were discussing how we really don't notice any movement anymore and don't use any extra stabilizers like we used to. So we must have gotten used to it!
Old 07-27-2021, 03:46 PM   #14
Homebrew's Avatar
🤣🤣 I only notice the movement when watching tv on the bed and the wife is walking around.
My last TT had x chocks which solved the movement. But don’t care any more, just yell and say sit down! 🤣
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 07-27-2021, 04:09 PM   #15
timm9's Avatar
Hi Relder,
As a fellow 2883ws owner I was going to purchase one but as other have stated it really does not need one.
timm9 is offline   Reply With Quote
Old 07-27-2021, 06:10 PM   #16
Thanks Timm9,
will hold off for now. Still hope the unit is delivered late September to mid October, although not holding my breath.
Old 07-27-2021, 08:50 PM   #17
Always Learning
I swear it's a herd of elephants some days!
Old 07-28-2021, 09:19 AM   #18
I'm of the other school. When we set up I use mine with great success. I get up early when we long term at the beach, and my tripod stops a lot of bounce when I go out to walk the beach at 5 am and my DW is still sleeping. I would not argue that Strongarms or some such other system works as well or better, as I haven't tried them, but my tripod works fine. I also use screw crank jack stands under the rear of the frame to create a more stable floor. Again I only go through the hassle of setting them up when we are long term, but it helps. If you use it properly, it also stops a lot of fore and aft movement. Correct installation is key. The chains need to be pulled tight, and readjusted if the feet slip out, and the head unit needs to stay cranked up tight. I just throw it in the back of my pickup where it lives unless used.
https://www.amazon.com/EAZ-LIFT-4886...481952&sr=8-17
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 07-28-2021, 11:15 AM   #19
never owned a tripod jack. for euther of my 5th / w trailers . rarely put down rear stabilizers , and in texas its windy , i guess some trailers rock a lot, both of mine were at 8500#, and 11700# . if it gets bad windy "like 65mph + ill put goose hitch on truck turn over ball , with legs just touching ground. and rear jacks down.
Thomas ho is offline   Reply With Quote
Old 07-28-2021, 11:37 AM   #20
Sorry... this made me grin!
The written word can certainly be interpreted many ways.
In this case, it seems to me, the tripod is stopping the bounce of you walking the beach at 5 AM! That is a good tripod!
stabilizer
