10-29-2018, 04:11 PM
When parking my new 5er for winter
Do I need to put the rear levelers down in winter storage or leave them up? I'm going to park it outside in the elements. I'm thinking leave them up off the ground ,fully retracted . This way the cylinder will not rust. Any suggestions??
10-29-2018, 04:12 PM
Anywhere my 5er is not connected to my truck, I use Auto Level and leave it level.
FROG AR-0019-242
10-29-2018, 04:39 PM
Ok , I just thought the cylinder would rust. I left my log splitter out side for a long period of time and forgot to retract it and it had some rust on it. Then when I used it the seals went bad
10-29-2018, 04:50 PM
I leave ours up all winter
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
10-29-2018, 04:51 PM
Rust can form on the chrome rod if it is poorly chromed or you had nicked it. Most cylinders can withstand weather without adverse effects.
If you have concerns, there are plenty of spray on rust inhibitors available.
10-29-2018, 05:09 PM
Yes your correct, I didn't think about just greasing them up. So I guess I will set it level ,put some wood under the tires and call it a night
10-29-2018, 05:13 PM
Denver To Yuma In 90 Days
I only have my front legs down on my 5'ver now while in storage.
Four wheels and two legs are all that is really needed on the ground for it to sit for long periods of time.
10-29-2018, 06:10 PM
Plus, if you leave after Christmas for a warmer climate, as we do, you only have to worry about retracting two cylinders with cold, syrupy hydraulic fluid instead of six.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
10-29-2018, 08:45 PM
Thank you
10-29-2018, 08:47 PM
I think I will only put the front legs down, thank you all for the info.
10-30-2018, 01:38 PM
do you live in an area where you have frost?
neighbor this spring had to replace their trailer floor because they set the stabilizer jacks down for the winter. Frost heaved the trailer uneven over 2 winters and destroyed its floor.
ref another FR topic
http://www.forestriverforums.com/for...ge-126422.html
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
10-31-2018, 07:33 AM
I was advised, and use, Silicone Spray. Periodically on legs.
10-31-2018, 07:55 AM
I only leave the front landing gear extended. The four leveling jacks remain stowed and out of the elements and I’ve never had a problem. I always spray silicone lubricant on the extended jacks prior to retraction and give them a wipe down. I believe that keeping them clean helps to protect your seals.
As Capt Mike said if you depart in the dead of winter there’s less stress on the system when you only extend two jacks rather than 6. As a side note if I have to use the jacks in the winter I’ve found that it helps immensely to place a car warmer near the hydraulic pump and reservoir for a few hours. It reduces the stress on the system and makes it work far better when the fluid is warm.
Cheers
Flatlander
2015 Silverback 29IK
2010 Silverado 2500HD LTZ
6.6 Duramax / Allison 1000
