The stickers aren't sending a nice message . . .
The maximum cargo weight allowed is 210 kg and when the water tanks are full the weight is 211 kg. There's no place left for any gear!
Not mentioned is the GWVR, from numbers above the weight should be 1,706 kg (3753 lbs)
Is this trailer running on 3,500 axles?
Its time to talk with the factory and confirm or replace the yellow stickers.
What's the dry tongue weight? And where are the water tanks (fresh and black) in relation to the axle? (weight shift from fresh to black will impact TW)
Canadian and American water are the same, they brew great
and good times.
