Originally Posted by 5picker
What's to install?
Assemble the dish to the mount, connect it to the router and use the app to get you going. This assumes you are setting the dish on the ground and not wanting it mounted to your home roof or other structure.
Since you are on a R/V forum, mounting to a flagpole or ladder is pretty simple if you go that route.
Here's a video that might help...
5 picker is correct, if you are setting it on the ground, the included stand will work. However, if the antenna needs to be higher to avoid obstructions (like your camper), you will need a different mount.
The Starlink app for your phone allows you to survey for obstructions.
Fred W
