Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-20-2019, 12:32 PM   #1
Fully COVID-19 vaccinated
Will the fridge work with propane shutoff?
I haven't tried it but Im curious if the fridge would stay cold without propane provided we are connected to shore power?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is online now   Reply With Quote
Old 03-20-2019, 12:36 PM   #2
ben31's Avatar
It depends on the fridge. Most, which work on propane, also work off either 12V or 120V (or both). Both would should work on shore power (assuming no issues). Your owners manual will have that information for you.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 03-20-2019, 12:41 PM   #3
Georgia Rally Coordinator
aceinspp's Avatar
If your fridge is set to auto then it will switch to Electric when camper plugged in. Once unplugged it will revert back to propane. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-6 days
Old 03-20-2019, 02:52 PM   #4
The only caveat is that there have been reports that some fridges starts up on propane when you first turn it on and then switch to electric, so with the propane off it's possible that if the power went off, the fridge would fault and not start back up on electric. I've never seen this, I'm just reporting what I've seen reported.
Gotta go campin!
Old 03-22-2019, 06:23 AM   #5
We have a FORESTRIVER WILDWOOD 241QBXL the frigidaire has AUTO and I'm wonder if while traveling if it runs on propane or the battery.
Ar-Newbee is offline   Reply With Quote
Old 03-22-2019, 06:33 AM   #6
bubbles's Avatar
Frigidaire, sounds like a residential fridge. Does it have a propane option?
Old 03-22-2019, 06:41 AM   #7
It is not a residential.
Old 03-22-2019, 06:47 AM   #8
Are you confusing Frigidaire with refrigerator? Frigidaire would not have propane. Frigidaire is a brand name of a residential fridge. BUT since you said you have AUTO I can only assume it is not a Frigidaire and yes it runs on Propane when in Auto while traveling.
Old 03-22-2019, 07:01 AM   #9
aceinspp's Avatar
Open frig door look for on/off switch. This has to be turned on before you start the auto or gas modes. if it says auto then it should have the gas option. Look right of auto should say gas. In auto position frig will default to gas when power is disconnect and vise versa when you plug back in to electric. Later RJD
Days camped 2019 62
Old 03-22-2019, 10:10 AM   #10
Misfit Adventures
Misfit011's Avatar
Misfit011 is offline   Reply With Quote
Old 03-23-2019, 10:23 PM   #11
I have to turn my gas off when connected to shore power because it will run off gas instead of shore power as long as gas is still on. Head scratcher!! Never have figured that one out
happyttowner is offline   Reply With Quote
fridge, propane
