Old 03-07-2021, 04:31 PM   #1
Will this generator run camper
Hello I have 2018 23mk grey wolf and I found a great deal on a generac iq3500 watt inverter generator will this run my a/c and everything else.??
Greywolf315 is offline   Reply With Quote
Old 03-07-2021, 04:58 PM   #2
Yes that will run everything in the camper.
Palamino Puma Unleashed 27 SBU
Aladin Sane is offline   Reply With Quote
Old 03-07-2021, 04:59 PM   #3
Ok thank you. I am picking it up basically brand new for $500
Old 03-07-2021, 05:15 PM   #4
Flybob's Avatar
You will have the ability to run basically what you can with a 30A shore power site. So it will run everything, but not at once. Figure continuous load about 25A.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-07-2021, 05:24 PM   #5
Oh really I was told I would be able to run my ac microwave fridge ect
Old 03-07-2021, 05:32 PM   #6
Flybob's Avatar
3500W at 120V is 29A in a perfect world with no loss.
TST Tire Monitors
2 100W solar panels
Old 03-07-2021, 05:33 PM   #7
Even if you're hooked up to a 30A, you can't run 'everything' at once without tripping a breaker. It's all about managing your power.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 03-07-2021, 05:59 PM   #8
As Flybob said, you can pretty much do with the generator what you could on a 30 amp service.
The issues arise when you are using several larger loads at the same time.
Consider that an A/C unit will draw around 12 amp while running but closer to 20 amp while starting.
The Microwave will draw 11-12 amp while running, slightly more when starting.
A converter, while charging batteries from a deep discharge will draw 700+ watts or 6 to 9 amps.
The electric element on a hot water heater (1400-1500 watts) will draw up to 12.5 amps.
Adding these loads alone runs your 30 amp shore power demand up to 45 amps and I know from personal experience that will trip the 30 amp breaker.
While running off the generator you'll want to make sure the water heater is running on propane only and charge your batteries early in the day so the converter isn't overloading the system when the A/C is needed.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 03-07-2021, 06:06 PM   #9
REL
Running the air and a coffee maker or air and microwave at the same time will be questionable. We have a predator 3500 and will turn the air off when briefly using those appliances.
REL is offline   Reply With Quote
Old 03-07-2021, 06:13 PM   #10
Right. Everything but not all at once.
ppine is offline   Reply With Quote
Old 03-07-2021, 06:30 PM   #11
Yes, you'll learn about managing the power. You think you're good then someone needs to blow dry their hair and you're looking for popped breakers.
Robbie D. Camper is offline   Reply With Quote
Old 03-08-2021, 02:07 PM   #12
dwilli1's Avatar
I recently bought the same model and coming from a "non-inverter type" life I am amazed at how quiet this unit is. I'm sure others that are similiar, Honda, Champion, Westinghouse, etc. are just as quiet. Still is nice not having to scream over the noise.
2024 Rockwood 2608BS towed by:
2020 GMC 2500HD AT4 w/Duramax 6.6 Diesel
Fastway e2 Equalizer Hitch
Trek Fuel EX7 gen 5
dwilli1 is offline   Reply With Quote
camper, generator
