Old 03-27-2021, 08:47 PM   #1
Winegard air 360 +
Question, all the videos for this unit show it being supplied with a red rocker-type power switch. Anyway, I have a River Ranch and I can't find the power switch to this unit..
chadjones99 is offline   Reply With Quote
Old 03-27-2021, 09:38 PM   #2
Is there a tiny push button on the faceplate where your coax connection for the TV is.
Cdj8465 is offline   Reply With Quote
Old 03-28-2021, 01:35 PM   #3
push button
Yes the living room TV has a small push button on the wall plate with a green light, But this is for the antenna booster in the winegard 360 + not the cell / wifi portion
IF you turn off the antenna booster button on the wall plate the unit is still broadcasting wifi signal and 4G cell signal ( well you can still log on to its wifi and select cell providers , etc )
Old 03-28-2021, 04:30 PM   #4
Boborc's Avatar
Do you have the Gateway installed? If not it is just an antenna you need the other module for it to be a Wifi/Cell unit
https://winegard.com/products/cellul...IaArtwEALw_wcB
If the Gateway is installed there should be a white box like mounted under you ceiling where the antenna is on the roof, there should be a switch near by
2021 Apex 253RLS
2015 GMC Canyon
Boborc is offline   Reply With Quote
Old 03-29-2021, 02:12 PM   #5
ya its wifi
Yes, it is installed by the factory as I have a 2021 RV .I have the Winegard 360 + and yes it has the WIFI white square box under it in the RV broadcasting wifi. I do not want it using the power and I do not want Wifi broadcasting in my RV that I am not using. This is why I am looking for a power switch. Not the power switch on the TV booster which feeds the antenna in the Winegard 360 but the power to the LTE card and wifi router built-in.. the video online and the PDF download manual show a red rocker-type power switch that they come with. The white box under it on the inside roof of my RV has a wifi symbol on it and I am picking up its wifi source on my phone as an available network I even logged into it using the supplied router password so Yes I know what I have. just want to down power it.
thanks
Old 03-29-2021, 05:35 PM   #6
Boborc's Avatar
If there is not a switch near by, they might have by passed it and just wired it hot. Take the cover off of the box inside (it will slide in one direction) unscrew it from the ceiling and see if they just tied the switch wires together. If they did you can get a switch of your own and mount it where you like. They probably just twisted the wires together to eliminate the switch. When I installed mine the switch was a pain to fit in the ceiling. I have a feeling they cheated and took the easy way out
2021 Apex 253RLS
2015 GMC Canyon
winegard
