I know nothing specific about the Palomino, but these so called winter packages, heated underbelly, heated basement, fully enclosed and heated tanks are just words. Nothing more nothing less.
Having said that, if the trailer has heated tanks the switch could easily be elsewhere and if the tanks are not heated heat pads can be retrofitted. In my experience it is not the tanks that freeze up first it is the blade valves, they need to be wrapped in heat tape and insulated more than the tanks themselves. The same goes for the fresh water line from the tank to the pump, heat taped and insulated.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
