Check the manuals for your dishwasher and washer. My Splendide washer came with winterizing instructions.
On my icemaker, I have a Tee near the water shutoff valve under the camper. I have a plug in the Tee and remove it to get water out of the icemaker line. While the plug is removed, I cycle the icemaker 3 or 4 times with a jumper wire. This opens the fill solenoid valve so the water in the line from the valve to the Tee will drain. Then, I put the plug back in the Tee. When I have the system pressurized with antifreeze, I again cycle the freezer with the jumper wire to let the antifreeze flow through the line all the way to the icemaker. If you are not comfortable using a jumper, you can just wait several hours for the icemaker to cycle several times.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
