Old 10-17-2019, 11:36 AM   #1
Winterizing a Flagstaff superlite
I'm new to TT world, and wanting to learn how to winterize my 2019 Flagstaff TT. Any good videos or discussions I can learn from?
Mike485 is offline   Reply With Quote
Old 10-17-2019, 11:46 AM   #2
The process is more or less the same for most trailers. Do a search for "Winterize" and you'll have lots of reading material.
Here's a start:
http://www.forestriverforums.com/for...rchid=11315652
Iwritecode is online now   Reply With Quote
Old 10-17-2019, 12:03 PM   #3
Chief T's Avatar
Just remember to take your time. I rushed things and when I switched over the bypass, I forget to turn the hot & cold valves. When I turned on the pump, fluid was streaming out of the water heater.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 10-17-2019, 09:28 PM   #4
WFD
Also search on Youtube...there are a few great videos that some RV Techs have posted. Although it likely won't be for your exact model, most are quite similar and will probably suffice for you to figure it out.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-18-2019, 08:43 PM   #5
The only tricky part...
The only tricky part (for a newbie) is the valves for bypassing the water heater before you drain it and winterize the rest of the water system.
First, finding them. Figure out where the water heater door is outside the unit. Then go to approximately that area inside the trailer to find the other end of the heater. It might be behind a screwed-on panel, a drawer, or a cabinet door (possibly one with hinges on both sides).
Second, there could be one, two, or three valves depending on what scheme was used. Just turn ALL of the valves to the opposite state. Restore the original state in the spring. Take a picture with your phone if you like.
Larry
Larry-NC is offline   Reply With Quote
Old 10-19-2019, 12:37 PM   #6
Pockets
If you PM me with your email addr, I will send you the spread sheet I use to winterize my Flagstaff 26RBSS. Just tic off the boxes as you do them.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
Pockets is offline   Reply With Quote
Old 10-26-2019, 09:08 PM   #7
Exactly what I do.
clcornell is offline   Reply With Quote
flagstaff, lite, winter
