What 5picker said. You're probably envisioning cutting the existing suction line to install the Tee. BUT: Don't cut the existing suction line. Just remove it from the pump, put your Tee on the end, and use another piece of hose to attach the Tee to the pump.
Also, the suction line doesn't need to be attached to one of the top Tee connections, as you may also be envisioning; it can be attached to any of the 3 connections. Attaching it to the bottom of the Tee might allow you to effectively install an "elbow" in the line. That might allow you to keep the pump where it is.
2011 Traverse LT, 3.6L, FWD
