Wolfpack 315pack12 exterior cable/sat problem
I just purchased a new 2020 Wolfpack 315pack12 and on my way home from the dealership I purchased I had an issue connecting my Dish Playmaker to the external coax lines (two labeled Cable/Satellite). It would not pass the signal thru to any outlet inside. There are 4 coax connection points (bedroom, two above fireplace and one in garage) Does anyone know if there is a junction box located somewhere? It comes with the Wingard Air and before I crack it open to see if I can disconnect or tap into it with my Playmaker coax I thought I would ask if someone had this issue or knows. Thx
