Old 02-07-2023, 12:26 PM   #21
Is the vent in the bathroom? The spot in your first pic is below the furnace. When you used the shower it got bigger. Is it currently raining? What is in the hole below the furnace, a drain pipe from the sink to the tub?
Cross-threading works better than blue loctite.
Capacitor is online now   Reply With Quote
Old 02-07-2023, 12:35 PM   #22
Newbiervgirl's Avatar
The vent is in the bathroom and I first saw those drippings when we had the river rains happen here in California. Yes, when I used the shower I saw more of a puddle again. I will remove that piece of wood and see what's behind it and send a pic..
Newbiervgirl is offline   Reply With Quote
Old 02-07-2023, 12:40 PM   #23
From what I can see there doesn't seem to be any water on the floor?
https://photos.app.goo.gl/g9VSkRBKPKPjUNmw8
Old 02-07-2023, 12:42 PM   #24
njfishing's Avatar
Originally Posted by Newbiervgirl View Post
Hello all,
Since after my last post I have made a couple of discoveries. I saw some droplets of water on the bathroom floor and I looked up and could see there were some drops coming from the vent. I cleaned them up and used the shower and tub and now there is a larger amount of water from that same spot in the very first picture. Is this the whole "must be a leak in the roof thing then? "
https://photos.app.goo.gl/cvDxbdcbm7GNXYni7
First thing I’d check is for cracked vent cover. If it’s not cracked you’ll need to go up on the roof and inspect the layer of caulk around the vent that seals it to the roof. If there are any voids you could try and add some sealer or you may have to remove and reseal the entire fan. Here is a video on that https://youtu.be/b_USGR5BzVs
If you’re not handy or don’t like getting up on the roof you might be better off having this done by a professional
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is offline   Reply With Quote
Old 02-07-2023, 12:46 PM   #25
bikendan's Avatar
It might help if you posted the model number of your trailer. Saying it's 21ft doesn't help much. Then we might be able to find a pic of your floorplan.
Old 02-07-2023, 01:06 PM   #26
wmtire's Avatar
Hi pretty close to it it's says 17bh? But the kitchen sink meets the bathroom in this same way.
I believe it's a 17bh.
2011 Flagstaff 831 RLBSS
Old 02-07-2023, 01:07 PM   #27
Thank you so very much! That is something to go off of and I will ask one of my handy neighbors with a ladder to help me with this at least to identify what's going on!
Oh I actually posted a pic of my floor plan on this thread on one of the links maybe it's underneath the floor plan pic that I received?
Old 02-07-2023, 01:09 PM   #28
Here it is again...
https://photos.app.goo.gl/A3WW4HMHZtJkAu6y8
Old 02-07-2023, 01:48 PM   #29
You should visit your welcome packet email and follow the instruction on how to post a photo into your post. Makes it easier for everyone to not have to leave the site to look at a photo.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-07-2023, 02:33 PM   #30
Okay good idea I will take a look at that as well. I can see here the icon for posting a picture but it doesn't allow me to go into my photos for some reason so that's why I have been using the create a link option. Thank you again!
Old 02-07-2023, 03:26 PM   #31
bikendan's Avatar
I think this is her floorplan
https://www.rvusa.com/rv-guide/2018-...n-17bh-tr36073
Old 02-07-2023, 03:42 PM   #32
Yes it sure is thank you!
Old 02-07-2023, 05:54 PM   #33
The paperclip icon
If you are using the computer/web browser, click the paperclip icon at the top of the editor and follow the instructions on the popup. You will be able to navigate the entire file system. When you have selected up to five items (one-at-a-time, you can upload them and then close the popup.
Larry
Larry-NC is offline   Reply With Quote
Old 02-07-2023, 06:12 PM   #34
Hi Larry thank you I will try it!
Old 02-07-2023, 06:31 PM   #35
Instead of Reply...
Instead of using Reply to respond to our messages, click the button labelled "Quote." It will include the message you are responding to in your message, so everyone can tell who you are responding to.
Larry
Old 02-07-2023, 06:46 PM   #36
Post #8 here.
https://www.forestriverforums.com/fo...an-211152.html
Had this on mine also. And #10 shows a good picture of a possibility. I just had to dab a little dicor into the holes for the clips, four of them.
Look for any cracking or sealant that can be pulled up.
I removed the trim piece at the ceiling and fan and it gave me a better idea of where the water was originating.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 02-07-2023, 07:13 PM   #37
Even better! Thank you everyone for the tutorial today you have all been most helpful I really appreciate this!
And now I can see the attachment clip which I was not seeing before so I will get the photo thing down too! 😁👍😊
Old 02-07-2023, 07:23 PM   #38
Mr. Dan's Avatar
As has been suggested, open your recently received Welcome PM, locate and click on the link to "Forums 101" and read the how-tos of this forum including post #7 and its pic posting instructions.
Old 02-07-2023, 08:35 PM   #39
Again, thank you for the more specific details I appreciate it 👍😊
Old 02-07-2023, 09:45 PM   #40
I have had rainwater blow in my shower vent during periods of heavy rain and wind.
You are going to need to start eliminating things. Start by drying the floor when it is not raining. Does a puddle reform? (leaky pipe connection is the culbrit) No pudde, then shower and see if the pudde reforms. Continue trying to eliminate possibilities.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
water
