Old 11-12-2017, 03:27 PM   #1
selandbe's Avatar
#1 motor Battery Dropout ... 2018 XLR Hyper Lite 29HFS slide out NEED HELP
Need help ... i have a 2018 XLR Hyper Lite 29HFS and the slide out stopped working ... everything else works fine and battery is at full charge ... i have even tried to run camper with my external generator and still doesn't work ... i pulled the cover off of the box under the slide out and the LED lights in box are blinking 1 green and 2 red ... which is supposed to mean the number one motor said battery dropout ... but i have no idea what that means or how to fix it ... can anyone help?
selandbe is offline   Reply With Quote
Old 11-21-2017, 07:00 PM   #2
WolfWhistle's Avatar
You probably already figured this out. I just now saw your post. I would check the connector to motor #1. Be sure it is plugged in okay. "Battery drop out" means the motor reported 6 volts or less. You can read on the photo how to manually override printed on the controller. It says, press a certain button 6 times then hold it in on the 7th time until LED start flashing, then use the manual switch to retract room. I always, always be sure nothing is in the way to let it move freely.
WW
Name:	c2 controller.jpg
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 11-21-2017, 07:28 PM   #3
selandbe's Avatar
Wolfwhisle ... thanks for the help ... i have actually NOT figured this out yet and i may just have to take it in for service ... i tried resetting this as you have pointed out and now instead of the battery drop out code it is now showing a code for battery low ... which doesn't make sense ... because i had the camper hooked up to the generator at the time ... so I'm still lost on this issue ... but thanks again for trying to help
Old 11-22-2017, 08:42 AM   #4
With only one motor shows these error codes, I would think, would point to a motor or control board fault. But, if that motor was drawing above normal amps... working too hard (viz: physically binding) its fixed resistance could drop voltage level to those alarm points. I hope its still under warranty.
Best wishes,
WW
Hyper Lite was sold
Old 04-18-2018, 01:26 PM   #5
selandbe's Avatar
The dealer said it was a faulty control board ... they replaced it and no more issues
battery, lite, slide, slide out, xlr
