Is there a website to be able to buy replacement parts for the camper or is it something you just have to call forest river for?
I have a few issues I need deal with... like a propane line seems to be leaking, a corner piece from the slide, and a rubber seal for the awning rail mount.
The gas line is standard and you can find a replacement easily online. Just make sure you realize the connections have reducers that need to be removed from hose. The vinyl weatherstripping went bad within two years, so i replaced it all. This is what I used.
The piece on the slide out is probably something you will have to order from forest river.
