Originally Posted by DC23
I am guessing the reason the area is blocked off is the concern of the plumbing being exposed, but if you aware of it you can utilize the extra space.
I will redo all the divider walls, as I agree you don't want anything in storage coming in contact with the plumbing/electrical.
The part I didn't like, is that they didn't even try to keep the area a bit compact to be able to take advantage of the horribly wasted space. Also don't like how the water lines & electrical have been run. Just seems like a complete mess, with no regard to tying up wires or hoses, or to keep stuff from rubbing on each other. (p-clips are your friend!!!)
When I redo mine, I'll take before and after pictures. (but this won't happen until spring)
