Old 11-20-2017, 06:14 PM   #1
Battery power problem 29hfs
i have a xlr 29hfs hyperlite and ive never been able to run of of battery power. the battery is there and charged but never works. there is a terminal block on the tongue. i have 12 volts one the wire from the battery but not on any other wires? i cant find a wiring diagram anywhere. was just wondering where the 12v go's after the battery so i can start checking things. any ideas?
the top right wire has 12volts on it from the battery but nothing else does.
forrest46 is offline   Reply With Quote
Old 11-20-2017, 06:54 PM   #2
fonzie's Avatar
If the studded connections are the same as in picture below, then see if there is a small black button that you can press to reset circuit breaker
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 11-20-2017, 07:08 PM   #3
yeah the small button was tripped but i pushed it in and still no voltage but to the wire feeding the block from the battery.
Old 11-20-2017, 08:04 PM   #4
Casey & Carolyn
Casey r's Avatar
Thinking if you reset the circuit breaker but still only have power on one side you may have a bad circuit breaker. Or possibly a short that blows the breaker again right away. If you have a multimeter see what kind of a draw you have between the 2 posts on the breaker.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
Old 11-21-2017, 02:07 PM   #5
Just a thought. There is a battery shutoff key inside the trailer, should be under the thermostat by the floor. This could be bad and not allowing 12v to the TT.
Bnrc73 is offline   Reply With Quote
Old 11-21-2017, 06:37 PM   #6
WolfWhistle's Avatar
F, using your photo that I flipped over, I added how mine was originally. Like was pointed out, that 12v from the battery should get thru the main breaker (with the small black button) and on inside to the battery cutoff. The 12v comes back to the copper bus which powers other things thru other breakers. Your wiring looks different, so maybe the wiring to and from the cutoff switch has been tampered with??
ID:	156941   Click image for larger version
Name:	wheres the switch.png
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 11-23-2017, 12:54 PM   #7
the little circuit breaker was bad from the factory, i went and bought one from auto parts store and works fine. thanks for the help guys
battery, power
