03-18-2017, 12:48 PM
Electric help 12V power
Cannot turn on house lights unless plugged in shore power.
When try and run on battery no lights in house including light in fridge.
Battery is good - was tested and hooked up correct.
All fuses are good.
Any ideas?
03-18-2017, 12:55 PM
Is anything 12 volt working? maybe battery disconnect is unplugged/off now allowing juice to flow? Battery would still test good. Are you checking 12 volt fuses or breakers? How big is the camper, a small one with one master switch that is off not allowing anything on?
03-18-2017, 01:01 PM
Check the battery disconnect and ensure it is set to send power to the rig. Yours may have as fuse located just aft of the batter on the frame rail if so check that.
Retired Navy
2016 Flagstaff 26 FKWS
03-18-2017, 01:17 PM
It's a Xlr Hyperlite 29hfs
Nothing 12 volt working.......battery disconnect is in correct position.
03-18-2017, 01:25 PM
Check for fuse/circuit breaker under frame behind battery.
2011 Traverse LT, 3.6L, FWD
03-18-2017, 01:37 PM
This is what I got. Can't find fuse
03-18-2017, 01:46 PM
Originally Posted by Deano777
No fuse from battery to frame.....
03-18-2017, 01:48 PM
Follow the big red wire back under the frame. It'll connect with a ring terminal to a circuit breaker, a little tin box with a reset switch on the side.
03-18-2017, 01:57 PM
This box in front of battery under frame. No switch just wires.....
03-18-2017, 02:07 PM
Too old to be too smart
I believe I can see your circuit breaker in the photo in your Post #7 above.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
03-18-2017, 02:10 PM
In your photo it looks like the battery + is going to the circuit breaker. It is only about 1 inch square.. check this area out from your pic
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Originally Posted by SpringerPop
Two little screws allow that cover plate to be removed so you can see what's inside.
The "little tin box" you're looking for would easily fit inside that double duplex connection box.
Pop
No fuse.....or reset switch
03-18-2017, 02:12 PM
03-18-2017, 02:14 PM
In case you missed it look at my post #11..
03-18-2017, 02:16 PM
Originally Posted by dalford
Ok I see those. I've followed the red and black wire from battery to this breaker. How do u reset?
03-18-2017, 02:18 PM
I edited my post #10 above to add a photo.
Pop
Little button between the two terminals. Push.
Pop
03-18-2017, 03:06 PM
Yes that red wire goes to battery +.
Took all 4 circuit breakers off. No push pop...... like a GFI but won't stay in......
03-18-2017, 03:28 PM
Pop
Must be the problem. Did you check voltage on output side?
03-18-2017, 03:29 PM
