Old 06-24-2018, 12:45 PM   #1
Electrical problem
I have a 2018 30hds hyperlite. Using a buffer in the plug in the garage, the buffer quit working on that plug and also the plugs behind the recliners and the tv. They are all gfic. When I reset the bathroom gfic they still don't work but the bathroom one does. I can't find another gfic to reset . Any ideas on how to fix my problem? Thanks
DanSmolders is offline   Reply With Quote
Old 06-24-2018, 12:51 PM   #2
wmtire's Avatar
I assume you are meaning they are all GFCI "protected" by a main GFCI outlet..which means they are wired downstream from the main (which is the one that can be reset).
As far as a main GFCI outlet, they are usually located near sinks (bathroom and kitchen) but some are also in pass thru storage areas if you have such.
Maybe somebody with your same toy hauler will chime in.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 06-24-2018, 01:01 PM   #3
Look near your power distribution box. Ours has a GFI outlet on the side of the box that houses the 12V converter. Also look for a GFI Breaker on your 115V panel.
Larry L is offline   Reply With Quote
electric, electrical
