Old 05-24-2011, 10:38 PM   #1
Fresh water drain?
Silly question, but where is the fresh water drain? On my old WW there was a valve close by and similar to the black/gray valve. Not so on the XLR. There is a "low point drain" but it only drained for about 20 sec and stopped. The owners manual is a joke. Ideas?
Brian
2010 XLR 29CKV
2008 Chevy 2500HD Duramax
rcpd34 is offline   Reply With Quote
Old 05-25-2011, 08:03 AM   #2
prof_fate's Avatar
The low point drain AFAIK is to do a final drain of the lines in the lowest point, for say, winterizing.
If you see where the water fill is you can follow that underneath to your tank and there should be a valve there. I found mine as it was open when I first put water in the tank.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-25-2011, 02:18 PM   #3
I may have to get the creeper out. Problem may be I have an enclosed underbelly which makes it hard to see under there.
Brian
2010 XLR 29CKV
Old 05-25-2011, 02:29 PM   #4
prof_fate's Avatar
I actually drained my fresh water today in prep for camping this weekend (no need to take water with us) and it's a screw on cap right about where I said it was. I now recall that during delivery we were handed the cap and told to put it on before filling the tank and I forgot about it till I started to fill the tank then it was easy to find! LOL
2011 Grey Wolf 28BH
Old 05-25-2011, 02:32 PM   #5
Physically locate the white fresh water tank to where you can see it. Then, where the side of the tank is, on one side, you'll see a push/pull style valve. It should be right off of the side of the tank. Pull it open, and it drains. Be sure to close it when it empties. Randy
Old 05-25-2011, 07:35 PM   #6
My XLR has an 8" long pex pipe with a cap coming out the bottom of the fresh tank...hope this helps
popik is offline   Reply With Quote
Old 05-25-2011, 07:41 PM   #7
Thanks for the replies. I'll check tomorrow. Can anyone advise which side it's accessed by?
Brian
2010 XLR 29CKV
Old 12-30-2013, 09:50 PM   #8
My fresh water drain by rear axle you will see blue pex pipe
gary reinard is offline   Reply With Quote
