Old 03-13-2018, 06:53 PM   #1
Fresh Water Tank Drain On A Nitro 28KW
Hello all,
Towed my new toy hauler home with the fresh water tank filled. Dealer said to drain tank I needed to run water through the shower into the grey water tank and then use the hose drain the grey water tank. This seems incorrect to. Beside the two small. Low point drain hoses is there another valve to drain the fresh water tank? And where might it be located.
Thanks in Advance.
Alpha211 is offline   Reply With Quote
Old 03-13-2018, 07:10 PM   #2
I can't speak to your specific unit, but the first step is to crawl under your TT and look for the tank. If you do NOT have a covered underbelly, it should be easy to find. Look for a drain plug or drain valve on the bottom or side of the tank. My Roo and my Mini Lite both came with plugs. I had to add a valve myself.
If you unit has a covered underbelly, look for a drain hose. You may actually have two hoses, one for the drain and one for the vent.
You won't have a drain valve "inside" the TT unless your FW tank is mounted above the frame, which I doubt is the case.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-14-2018, 10:16 PM   #3
The water tank drains are on the left side by the axles on my 23KW
cra_fizzer is offline   Reply With Quote
drain, fresh water, tank, water, water tank
