I can't speak to your specific unit, but the first step is to crawl under your TT and look for the tank. If you do NOT have a covered underbelly, it should be easy to find. Look for a drain plug or drain valve on the bottom or side of the tank. My Roo and my Mini Lite both came with plugs. I had to add a valve myself.
If you unit has a covered underbelly, look for a drain hose. You may actually have two hoses, one for the drain and one for the vent.
You won't have a drain valve "inside" the TT unless your FW tank is mounted above the frame, which I doubt is the case.
2011 Traverse LT, 3.6L, FWD
