Old 03-26-2020, 06:04 PM   #1
Fuel station wiring
I have a 2018 Hyperlite 26HFS. The fuel gauge does not work. After having the dealership work on it and replace the gauge and sending unit it still does not work. I decided to look at it myself. After figuring out that the sending unit wasn't wired properly I figured out that the fuse between the switch and the gauge was blown. When I replace the fuse nothing will turn on (pump, light on gauge, gauge). If I take the ground off the gauge and push the switch the pump comes on, gauge light comes on, and gauge will peg past fuel. Has anyone had this issue? Got any ideas on what could be wrong?
MrFear is offline   Reply With Quote
fuel, wiring
« Rear cargo couch | - »
