Old 11-23-2020, 03:40 PM   #1
Haulintoys's Avatar
Furnace Filter? 2015 XLR HFS
Does my furnace have a filter? Fired right up yay! We are going cold weather camping this weekend. However, It smells like burnt dust, just like your home furance before a filter change. Is there a filter below that I need to change?
the one in the upper/AC/Fan area is brand new and that is not running on auto. That cannot be the source of the burnt dust.
2015 FR Hyper Lite 27HFS
2018 GMC Denali HD Duramax Diesel
Haulintoys is offline   Reply With Quote
Old 11-24-2020, 08:49 AM   #2
SeaDog's Avatar
There is no filter on your furnace what you smell is the light oil that is coating the firebox after mfg that smell will go away.
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-24-2020, 09:02 AM   #3
Homebrew's Avatar
Open some windows and turn on the exhaust fan and run the heater for 30 minutes.
Be prepared to deal with smoke detector going off.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 11-24-2020, 09:19 AM   #4
Haulintoys's Avatar
Thanks. The unit is 5 years old and had been used before, so it's def. a dust smell. I'll just crank it on with the fan and open my windows for a bit. Just making sure I didn't miss something I should be doing in regular maintenance.
Old 11-24-2020, 09:20 AM   #5
Haulintoys's Avatar
Good point. I'll pull the detectors out of the coach before I crank it all up.
Old 11-28-2020, 12:53 PM   #6
The Big Toe's Avatar
How do you 'pull' the smoke detectors?
Mine went off once and I don't remember for sure, but I may have had to disconnect the power. Or wait until it quit by itself.
I'd be grateful to know how you turn them off without a lot of rigamarole (is that a word?)
And, hoo boy, are they ever loud. Good thing I wasn't near a cemetary
The Big Toe is online now   Reply With Quote
Old 11-28-2020, 01:00 PM   #7
Just as confused as you
Scrapper's Avatar
I'd be grateful to know how you turn them off withou a lot of rigamarole (is that a word?)
The smoke detector is located on the ceiling and powered by a alkaline battery. If you have to disconnect the 12vdc power then it is your CO/LP detector. There is a big difference between the two.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Scrapper is online now   Reply With Quote
Old 11-28-2020, 03:15 PM   #8
Mine is not powered by a battery. It is a direct connection. It's on the ceiling near the front bedroom almost over the entertainment center on 29HFS. In front of the A/C
The time it was set off was me spraying bug spray trying to kill a mosquito invasion. (i hate mosquitos)
I assumed it was a smoke detector. I don't see anything to make me think other wise. Could be wrong. dunno
Old 12-08-2020, 05:03 PM   #9
bubbalowe's Avatar
My 2016 29HFS smoke detector is located in same spot but is indeed 9v battery powered. It doesnít take much campfire or grill smoke to set off. Just push in to release battery and let hang until going to bed, thatís when theyíre needed most anyhow.
bubbalowe is offline   Reply With Quote
furnace, xlr
