Old 10-15-2017, 11:41 AM   #1
Furnace operation
I read on the forum that the furnace runs on 12 volts. Is there a way to run the furnace while boondockng without 110v to power the thermostat with the controls?
Bnrc73 is offline   Reply With Quote
Old 10-15-2017, 12:10 PM   #2
A32Deuce's Avatar
My thermostat works on 12 volts. Use it if I stop for the night not in a CG. Works in between trips in the winter with heat set at 40 degrees.
A32Deuce is offline   Reply With Quote
Old 10-15-2017, 12:10 PM   #3
bubbles's Avatar
The furnace is 100% 12 volts DC and AC power is not part of the equation. The only thing that changes when shore power is connected is that the 12 volts from the converter supplements the battery (via charging) or supplies all the 12 volts required.
Old 10-15-2017, 12:10 PM   #4
Huh? Furnace needs 12VDC for the fan, ignition and thermostat operation. 120VAC is not needed. But a furnace can kill a decent battery in one night. So you will need a way to recharge your battery each day
donniedu is offline   Reply With Quote
Old 10-15-2017, 08:12 PM   #5
I'll check it out tomorrow. When the tt the thermostat is blank. But c one to think about it it's always in the off position when I unplug. I'll try turning it on with just the 12v in the morning.
Thanks for the help
Old 10-15-2017, 08:31 PM   #6
Herk7769's Avatar
Plugging and unplugging the line cord should be done with zero load on the camper to avoid sparks at the plug blades that will pit and overheat the connection.
I do this by turning off the breaker, either at the plug (shore power side) or the camper's main breaker (inside the camper). Once you are connected, then you just reset the breaker you switched off.
ID:	154329   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 10-16-2017, 01:20 PM   #7
Checked this am. Furnace does work all on 12v. Thanks everyone
Old 10-17-2017, 11:22 AM   #8
Or have a progressive EMS, it delays turn on about 10 sec.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
furnace
