Old 08-20-2018, 09:30 PM   #1
selandbe's Avatar
Generator size needed?
I have a 2018 XLR Hyper Lite 29HFS ... 30amp with the AC upgraded to the 15k BTU ... anyone know what size generator I need to purchase to run the whole camper?
Any help would be appreciated ... thanks
selandbe is offline   Reply With Quote
Old 08-20-2018, 09:42 PM   #2
Professional Curmudgeon
wrvond's Avatar
I wouldn’t go less than 3300 Watts.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 08-20-2018, 09:47 PM   #3
I have the 2018 30HDS with the same A/C. I got the Champion Inverter 3500 Daul fuel with electric start. It works great used it at the NASCAR race in July.
Tank
Tankmaster is offline   Reply With Quote
Old 08-21-2018, 08:03 AM   #4
I use a Champion 3100 Watt. It will run the 15K A/C, some lights and the tv, but I have to run my fridge and water heater on propane when using the generator.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 08-21-2018, 08:19 AM   #5
SeaDog's Avatar
I use two Yamaha's 2000s in parallel when I want to run the AC. For charging batteries and such I run just one keeps the noise down and fuel use to min.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-21-2018, 08:23 AM   #6
That was the reason I went with the 3500 plus the dual fuel. I found it at Cabelas for 915.00 with electric start. Runs everything just fine
Tank
Old 08-22-2018, 02:30 PM   #7
selandbe's Avatar
Tank
Do you have the Champion 3500 inverter or the 3400? I only ask because I can only find the 3400 inverter
Old 08-22-2018, 02:56 PM   #8
I have the 3500 inverter dual fuel. I got it at Cabelas with free shipping. The only other place I saw it was Camping World for much more.
Tank
Old 08-22-2018, 03:01 PM   #9
The 3100 wouldn't run the 13.5 on our old trailer, but a Yamaha 3000 would.
2017 Rockwood MiniLite 2506S
2019 GMC Sierra 6.2L
2017 Colorado D-Max pulling 2017 Tracker 175TXW
Days Camped in 2020: 7
bshort is offline   Reply With Quote
Old 08-22-2018, 03:24 PM   #10
3100 wouldn't run your 13.5 k ac something was wrong . maybe you had you electric water heater running , fridge , and microwave .
MR.M is offline   Reply With Quote
Old 08-22-2018, 03:25 PM   #11
Lacey's Spring, AL
formerFR's Avatar
it’s hard to know exactly what you mean by running your ‘whole camper’, but I suppose since it’s a 30amp coach, with a 30amp shore power cord, only up to 30amps would be needed, as far as maximum operational output for the generator.
I would suggest that 30amps equates to about a 3,600 watt generator, or slightly higher, with a 30amp RV outlet(for sure!)...
that could be a single ‘large’ generator, or a dual setup, like the Honda EU2000i and companion, small and light, hooked up in parallel when you need ‘all’ 30 amps.
The Turners
'14 Thor Palazzo 33.3 compact diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from GA, then NC, now N AL : )
formerFR is offline   Reply With Quote
generator
