Old 04-03-2013, 05:02 PM   #1
FunTimes27XLR's Avatar
Hot water heater xlr27fhs
Anyone know what the plug and cord would be for by the water heater under the bed
FunTimes27XLR is offline   Reply With Quote
Old 04-03-2013, 05:20 PM   #2
TURBS's Avatar
A picture is worth a THOUSAND words .
Old 04-03-2013, 06:18 PM   #3
Originally Posted by f1100turbo View Post
a picture is worth a thousand words .
Old 04-03-2013, 06:24 PM   #4
TURBS's Avatar
lol I would say it should be plugged in !
im guessing the hot water tank doesn't work on electric ?
Old 04-03-2013, 06:31 PM   #5
Not sure. Only camped twice and both times used gas didn't know it also had electric. Although both times the water never got really hot just Luke warm so I was looking around And came upon that. I also turned the cold water value off that ran between both hot and cold lines. I think to much cold water was blending. Does all this make sense?
Old 04-03-2013, 06:34 PM   #6
TURBS's Avatar
Yes, the cord should be your electric side of water heater.
Before plugging in make sure the switch on the outside of water heater is off.
Sounds like you may have the valve figured out.
Normally luke warm indicates that the bypass are in "by pass" or not fully turned allowing it to by pass cold water .
Turbs
Old 04-03-2013, 07:19 PM   #7
10x
Its under the bed? I will have to check mine.
10x is offline   Reply With Quote
Old 04-03-2013, 07:26 PM   #8
Turbs
The outside switch was on when I plugged it up. Should it always be off? And
Old 04-03-2013, 07:50 PM   #9
TURBS's Avatar
Only off if theres no water in tank.
You can also use gas and electric at the same time for quicker recovery rate!
Or separate if you wish.
Old 04-03-2013, 07:56 PM   #10
When you say both at the same time do you mean turn the switch on in the bathroom that says heater? If so then I think I have it figured out. Thank you so much. I'm a first time camper so I need all the help I can get.
Old 04-03-2013, 11:13 PM   #11
It looks like they forgot to plug in your water heater to run off electric. When I am plugged into power at the camp ground I leave the hot water switch in the bathroom off and turn on the power switch on the hot water heater. If you open the hot water heater compartment outside door and look around you will see an on/off rocker switch. If I need hot water faster I will turn both switches on.
Bathroom switch on = propane hot water.
Tank switch on = electric hot water
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
Kaboom is offline   Reply With Quote
Old 04-04-2013, 06:24 AM   #12
TURBS's Avatar
This switch for electric.
Old 04-08-2013, 07:39 AM   #13
Camped this weekend and had hot water. Thanks for your help
