Old 04-11-2018, 01:50 AM   #1
Lifting a XLR HL 29HFS by placing the axle below the leaf springs for better clearance
I'm thinking about lifting my XLR HL 29HFS by placing the axel below the leaf springs. I'm wondering if anyone has advice on the pros and cons/ side effects.
The main reason for doing the move is to gain more clearance for the plumbing and to be able to get into better camp spots without ripping off stabilizer jacks or getting hung up on the tail. I've watched some videos on how to do it on other travel trailers and think I can handle the process. Mostly curious about how the TT will handle on the road after being lifted by ~5 inches. Also wondering about how to add another step on my entrances.
jlittfin is offline   Reply With Quote
Old 04-11-2018, 07:23 AM   #2
SeaDog's Avatar
that is not an uncommon mod with rigs around my neck of the woods to get the clearance for hunting camp and backwoods camping. I have not heard of any handling problems, does require a larger block of wood under the tongue jack.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-14-2018, 11:49 AM   #3
rebel29144's Avatar
I Just put SaveAJack Jack savers on mine, hopefully this can solve some problems
rebel29144 is offline   Reply With Quote
Old 04-20-2018, 05:51 AM   #4
A possible con, depends on how you use it...my stock height 29HFS has a fairly steep ramp angle which can make loading a bike difficult (remedies/workarounds have been discussed many times on threads). Raising the frame will make this worse. Without knowing how you use this I have no idea if this will be a problem for you or not.
DennisTD is offline   Reply With Quote
lift, xlr
