Misbehaving Hydraulics
I'm stumped. I have a 2017 XLR 413AMP with a generator. For the winter I engaged the battery disconnect. I hooked a solar panel up to keep the batteries charged and went out to start the generator for some exercise. The battery is dead and I find out that the solar panel is toast. When I engage the battery disconnect for some light in the coach the jacks start retracting! I remove the "key" and the retraction stops. There's no question I need to charge the generator battery to get the generator to recharge the house battery, BUT the question is once the generator is running is that going to take care of the misbehaving hydraulics once I reengage the battery disconnect for power in the coach? If not is there a reset for the hydraulics? I've tried about everything and I can't get the control panel for the hydraulics to light up so I can at least stop the jacks from lowering the coach. Never had this problem before and thanks!
