Old 02-18-2020, 03:18 PM   #1
spring equalizers
Hi!! I have been thinking of changing out my leaf spring equalizers to Morryde. I have a 2015 XLR thunderbolt 401AMP with 3 axles. It looks like morryde are the only ones you can order for 3 axles. I see there is Lippert and Dexter but can't find any that make for 3 axles . Right now I need to work on my shackles as there is starting to show ware. I have been up to the Yukon and into Alaska. and last winter was in Yuma . [ I live in. Fort St John BC ] so have put the KM [miles] on. I thing I should do anyway is change all the shackles and bolts out to grease. kind.
So what has anymore else think Thanks
Julie dog is offline   Reply With Quote
Old 02-18-2020, 04:29 PM   #2
D W
D W's Avatar
Measure your current equalizers and match them up here:
https://www.etrailer.com/dept-pg-Tra...Equalizer.aspx
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 02-24-2020, 11:29 AM   #3
1 more thing I have been thinking about. is. ..Do I really need these equalizers , I have triple axles. I do want to change all the bolts out to grease type
Old 02-24-2020, 01:10 PM   #4
spicercars's Avatar
If your going to change out everything you might as well put in a wet bolt kit. Will last a lot longer.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
spicercars is online now   Reply With Quote
Old 02-24-2020, 06:08 PM   #5
saus's Avatar
I just changed mine out. I have the Morryde cre3000 and wanted to change them out for new ones. I measured everything and ordered the 35 inch equalizers. When I received them in the mail, they were larger than the existing ones on my fifth wheel. I called Morryde and they asked for my measurements. I gave them the measurements and they said that I definitely need the 35ís. They said that I have the 33ís on right now, which Forest River must have put on by mistake. In short, go to the Morryde website and look at the qualifying sheet that will tell you what to measure in order to get the right one. Good luck.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 02-24-2020, 06:16 PM   #6
saus's Avatar
They do make for a smoother ride and definitely get the wet bolt kit. Make sure your kit has enough bolts. My wet bolt kit came with just enough bolts for me to do just my two axles.
equalizer
