We have this antenna on the roof of our new XLR. We are brand new to the camper owner world and our dealer failed to show us how things worked
Any suggestions on getting this all set up?
We have the 32” tv that is installed.
Also, is there a way to have the sound from the furrion DVD player to play through all of the like surround sound?
That is a 360 degree Omnidirectional antenna. It's for receiving over the air broadcast channels. Should be a cable outlet right by the TV mount and it should have a little button on it that lights up green when you push it...(antenna booster) Run a cable from your TV input to that output connector, turn on booster, run a channel scan on TV.....be sure to set the scan to look for AIR channels. I had to run RCA cables to get mine to play thru the receiver in the TT.
