Update Warranty & Washed & Detailed
This may be in the wrong location but I thought I would give everyone an update from warranty work. After 7 long weeks, yea I said 7 long weeks I finally got my camper back. They were able to get the stickers on the back door from door adjustment from the August visit. They were able to realign the front door from scrubbing and repaint, the slide out they said they could not find anything wrong with it. Oh, I was also told that you can run slider in and out either with rams downs or rams up. I was always taught to have them down. Another day with that problem, they winterized it, did an inspection to check to make sure all was ok throughout the entire camper, and they worked on the leaking shower drain said it was a loose nut. I still saw play underneath and decided to put a shim of wood under there to help support. So between the August of 5 weeks and visit of Nov after thanksgiving/Dec. /Jan and picked up of this past Friday the 20th. All seems to be in order. I read a lot of thread where other have had problems and said you got to get through the first year. Wow, I bought this camper on June 5, 2016 and of the 7 months owned it has been in shop two times totaling 12 weeks. I hope all problems are solved and now time to enjoy again. Yea, I know is just January but the first Camping trip is Easter and that is Only 80 days away so we got to be ready right?
Today here in NC the temps are 61 degrees with rain but rain is rain and I don't let rain slow me down. I worked on staining new shelves inside just as you walk in the main door. I built last year but within the shop I'm just now getting to stain and varnish it. I got out today and washed and waxed her today, along with tires and underside. So here are some pictures of Maguire’s Spray on Wax and Armorial of tires and underside. I'm worn out. It sucks getting old.
Tim & Rita Coltrain in North Carolina
Tim & Rita Coltrain
2021 Chevrolet 3500 Duramax Crew Cab, Allison Tranny.
XLR Thunderbolt 2016
