11-08-2016, 03:29 PM
Winterizing
I have an XLR 29hfs and was reading about how to winterize. Manual says to put the non toxic antifreeze in the fresh water tank and then run it through the system. Does anyone have a trick on how to get the antifreeze into the
fresh water tank?
Bsquared
11-08-2016, 03:41 PM
bsquared,
Do a search of the forum BEFORE you put RV antifreeze in your fresh water tank.
There are several ways to get antifreeze into the plumbing without the hassle of putting it into your tank and having a devil of a time getting it flushed out come spring.
Just search 'winterizing' and you will have days worth of reading and tricks!
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
11-08-2016, 07:05 PM
There is a suction line and a valve behind the panel that you have to take screws out of to pump the antifreeze through your system be sure to drain and bypass the hot water heater.
11-08-2016, 07:09 PM
Do not recommend adding antifreeze in the FW tank. Very hard to get out. Use the antifreeze port next to the water pump. Also don't forget to bypass the water heater. You should need about 2Gal antifreeze.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-08-2016, 07:55 PM
Always Learning
Yep. I agree with the above... don't do it!
Here are my instructions for winterizing:
http://learntorv.com/winterizing-you...-water-system/
11-09-2016, 09:59 AM
Originally Posted by ependydad
Good article - thanks!
2014 Work & Play 30WRS
2006 Chevy 3500 Duramax
2001 Suburban 2500 6.0 (former tow rig, now just party wagon)
11-09-2016, 10:15 AM
Insert witty title here
Maybe I missed it but I didn't see the article mention the city water connection or the black tank rinse.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
11-09-2016, 10:20 AM
Always Learning
You're right. I need to add those- I've never dealt with them and have never had issues, but I can see it being a problem.
11-09-2016, 10:43 AM
This generic pic covers 95% of RV's. Maybe it will help.
2011 Traverse LT, 3.6L, FWD
11-13-2016, 10:05 PM
fresh water tank?
Bsquared
Remove the panel that is behind the door beneath the sink and stove top. You will see a valve and one hose connected to the valve is the siphon hose. This is on the input side of the pump. Turn the valve toward this hose and put the other end in the antifreeze jug. I would not put antifreeze in the fresh water tank. Also if you have a compressor you can blow the lines out before you put antifreeze in the lines.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
11-15-2016, 11:54 AM
Help!!!! Winterizing
I am planning to go to Stone Mtn Ga. the last week of Dec. 2016. I live in Fl. and never had to winterize my TT. Do I have to winterize to go to Ga.?
11-15-2016, 12:12 PM
If it were me, I'd wait and watch the weather forecasts the week before. Winterizing is easy so if you wait until the last minute, it shouldn't be a problem.
I assume you're camping once you get there? If so, it would have to get really cold for it to be a concern for me just for the drive up there.
You may be able to get by with just draining the water heater and opening up your low point drains.
11-28-2016, 10:02 AM
Would you leave a bit of the antifreeze in the toilet bowl?
Moyock, NC Carolina Panther Fan!!!
2018 Puma 23SBC Toy Hauler;
2014 Ford F150 XLT 4X4
2002 EZGO Golf Cart
11-28-2016, 10:25 AM
Yes. It keeps the seal from drying out.
11-28-2016, 10:47 AM
Thanks for all the suggestions. I went back and flushed the fresh water tank. Drained all tanks. Blew out all the lines with compressed air. Found the pump siphon line under the sink and pumped antifreeze through all the lines including city water line. Used hand pump to put antifreeze in black water flush line and fresh water line. I think I have it all covered now.
