Old 08-04-2021, 08:55 PM   #1
Black tank flush
First post so hopefully I don't get bashed too hard. I did try to search every possible way I could think of.
I am borrowing my stepdad's 2019 25RQGMX and am trying to figure out if what I'm looking at is a black tank flush hookup. There are a total of 3 water hose connections on it, 2 over on the left (street) side appropriately labeled "fresh water" and "city water" but there is one on the right (curb) side with no labeling whatsoever. They use the 3' wand attachment to clean the tank but I can't think of anything else that this port would be for...other than a flush but every trailer I've had/used with one has it clearly marked either "black tank flush" or "flush valve non-potable only"
Brewsky88 is offline   Reply With Quote
Old 08-04-2021, 09:06 PM   #2
Very possible it is the black tank flush.
There have been several posts on this and other R/V forums where the ports were mislabeled or not labeled at all.
Look inside the R/V where the port enters and see where the line goes.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 08-04-2021, 09:42 PM   #3
Every blank tank flush that I have ever seen has had a threaded collar so that the supply hose could be screwed on (just like city water). That connection does not look like it has threads in order to screw a hose onto it.
NavyLCDR is offline   Reply With Quote
Old 08-04-2021, 09:58 PM   #4
Retired Old Fart
dward51's Avatar
If you blow up the photo, it does have a round center. I think it's threaded and the angle makes the threads not really visible. It's probably the black tank flush inlet. If the black tank is empty, hook up a water hose to it and listen for the flow into the tank (follow the dump line to get an idea where the black tank is).
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 08-04-2021, 10:36 PM   #5
It is threaded and comes in here next to the feed lines for the sink across from the bathroom...presuming that's not a a feed line for a tank sprayer
Edit: not sure why my pictures are posting sideways
Old 08-04-2021, 10:47 PM   #6
Or maybe? Comes down and goes into the floor underneath the refrigerator, perhaps on track to the tank
Screw it, I'll pull the liner for the underbelly
Edit: nevermind, no I won't, liner may have bolts across the center but it has what appear to be those like concrete nails that are shot in with a .22 along the edge rail.
Staying in the trailer currently so I'll just hook up a hose and check next time I drain the tank.
Old 08-05-2021, 04:05 AM   #7
If it is the short hose with the two white fittings, and the picture is sideways so the hose actually goes up into the bottom of the black plastic item, and the elbow fittings comes out of the side of the black plastic item then....
The black plastic item is a vacuum breaker check valve which gets installed in the black tank flush line. When you apply pressure to the inlet, the check valve closes and water flows into the black tank flush nozzle(s). When you stop flushing the remaining water flows into the black water tank, the pressure on the check valve releases and it opens the top of the vacuum breaker valve to atmosphere to break the vacuum so there is no siphon effect.
So, that would be the black tank flush connection. Even though mine is different trailer, my black tank flush connection also comes in very close to the bathroom sink and the vacuum break anti-siphon check valve is under my bathroom sink.
Old 08-05-2021, 06:04 AM   #8
bubbles's Avatar
Actually when pressure is applied the check valve OPENS and at the same time the vacuum breaker is sealed (held sealed by pressure) and water flows to the tank nozzle. When pressure is removed the check valve CLOSES and the vacuum breaker seal opens and allows the remaining water in the valve cavity and input plumbing line to drain back out the input port when the port is opened to ambient (hose removed). Additionally, if factory installed, the check valve/vacuum breaker is supposed to be installed at least 6" above the toilet rim height no matter where it is located.
Old 08-05-2021, 06:05 AM   #9
isn't it easier to ask him?
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 08-05-2021, 06:38 AM   #10
Kanadian Kamper
kenandterry's Avatar
He did say he was borrowing his stepdad’s rig, I’m not sure that means his stepdad actually knows that though.
Shhhhhhh!
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 08-05-2021, 07:36 AM   #11
Yes, that is for the black tank flush.
Old 08-05-2021, 08:03 AM   #12
My black tank flush looks exactly like that. The threads are on the inside and connects to the male end of a hose.
Iwritecode is offline   Reply With Quote
Old 08-05-2021, 08:37 AM   #13
nomad297's Avatar
Based on the second picture you posted, I can say with certainty, that connection on the outside is the black tank flush connection.
Bruce
Old 08-05-2021, 03:41 PM   #14
As I mentioned, he uses the 3' wand connected to a hose because I even asked about if it had a flush and that was his answer. This is his first trailer in a long time and may not even know that these types of systems are available, just doing it how he always has, and has only had it out a few times.
It peaked my interest as a possibility because I had never seen an inlet completely separate from all of the other hook ups like this is that wasn't a flush, but had also never seen one not labeled. With how loaded this trailer is (fueling station, outside shower, electric bunks, electric rear door, generator) I'm making notes of all the perks and quirks I'm finding about it
Old 08-05-2021, 04:08 PM   #15
Chuck_S's Avatar
What's the worry about flushing the black tank? Just drain it, it doesn't need to be clean, just empty. If you poisoned the tank (anything blue) it will stink regardless.
An enzyme and Odorlos(tm) will continue to digest any small amount remaining after dumping leaving the tank cleaner than any flush. Been leaving waste in the tanks for decades with those treatments. Heck my boats required pumping to empty and we sure didn't flush them, just pumped every few months.
-- Chuck
Chuck_S is online now   Reply With Quote
black, black tank, black tank flush, flush, tank
