really depends on the floor width between the cabinets and walls. i would be more worried about ccc. if it doesn't have atleast 4k lbs of ccc then thats a no!
i just looked at the specs.... no info on width in front of the slide. call forest river to find out. 3100 ccc! what a joke. so your 4 seat sxs is 1800 to 2k lbs. lets just call it 2k lbs especially if you have larger tires on it let alone an actual roll cage or any upgrades. load the sxs backwards in that one and that leaves you 1100 lbs ccc left. your maxed out with empty tanks! you do not want to be maxed out, always want to be under the max limit and i don't mean by 10 lbs.....105 to 20% would be pre ferable imo.
'99 f350 drw
'21 dune sport fire storm custom toyhauler
