Old 11-28-2020, 11:01 AM   #21
Possibly the same issue, simple fix.
I also had some problems keeping the fridge lit when it was on gas. I checked the fitting leading to the fridge along the gas line and found 3 of them barely had tight. I snugged them up with a crescent wrench and the issue went away. I thought it was just another example of poor attention to details from the factory.
31NDUN is offline   Reply With Quote
Old 11-28-2020, 10:31 PM   #22
EJJ
Dometic Refrigerator 2852
The igniter was the issue with difficulty in starting, my next question is, do I have to have sufficient battery power to keep it running? I ask this because last week while camping with my grandson (self contained), the fridge burner would shut off sometime during the night, mind you now I was running the heater also on battery power, I do have 2 twelve volt deep cycles and solar panel to maintain charge. The batteries are at least 5 years old and here in Arizona you do good if a battery last that long, so when furnace would come on and run for a while, that may drain batteries low enough to shut off the fridge solenoids. Does this all sound reasonable?
Ernie
EJJ is offline   Reply With Quote
Old 11-28-2020, 10:50 PM   #23
Ernie
Yes.
Old 11-28-2020, 10:54 PM   #24
EJJ
That's what I thought, because I did turn the battery disconnect to check my hunch and it shut the fridge down, flame and all. So I guess replace both batteries.
Old 11-29-2020, 01:43 AM   #25
dbledan's Avatar
If the furnace is kicking on there should be enough battery power for the fridge. Its a very small draw for the fridge. My my two gc batteries i can get 10 days running mostly just the fridge. Now if the furnace killed the battery yes your fridge will not run either.
I would check for spiders and other insects by the gas output or around the igniter.
I would only swap the batteries after testing them to see if there is actually a problem unless you just want new ones.
dbledan is offline   Reply With Quote
Old 11-29-2020, 10:32 AM   #26
I agree with the other posters, check the batteries first. But, 5 year old batteries are pretty long in the tooth. If you are going to replace them I would consider a pair of 6 volt deep cycle. I have had both the pair of 12 volt and the pair of 6 volt, I had a better service life out of the 6 volt. The 6 volt I have used were nothing special, Walmart deep cycle 6 volt around $100 bucks each. We camp mostly without services, but I do have solar on the roof to keep them charged.
Old 11-29-2020, 11:03 AM   #27
EJJ
I have 2 12 volt interstate, originals that came with the trailer, also a 300 watt solar panel, I will load test them and go from there.
thanks
Old 11-29-2020, 02:19 PM   #28
bikendan's Avatar
thanks
Yep, those are the typical cheap dual-purpose marine batteries that most dealers install. They are not true deep cycle batteries, like a 6v golf cart battery.
toy hauler
