I just bought a 2018 Stealth 2916G Private Party. I can't figure out how to play music on the two speakers on the outside of the trailer. I can't seem to find the control for that and I don't see it in the owner's manual. Can anyone help please?
Here's the Forest River site's link to the audio visual PDFs for your 2018 Stealth; this should help. You can scroll down (on the right) to your particular system; I believe you said it was a Jensen?!
Usually there different speakers on different cirucuits. They might be labeled, 1,2,3 or A, B,C. Try all of them until you get outside sound. Similar to a home stereo system.
Is that factory of did someone install an aftermarket Kenwood? I've never seen a KW in a RV before.
Edit ------------------------
Ok, I was curious. It is apparently the Kenwood KDC-152 and is an option in that model. Here is a link to the PDF owners manual for the KDC-152. It only has the 4 speaker outputs, so it must be via the front/rear fader control to change from inside to out (or a mix of both):
