Stealth CR3716 Spring Hangers
Hi all. Trying to find out if anyone else has the issue I'm having. I've had my Stealth CR3716 triple axle for almost 7 years now. I just recently installed the MORryde cre3000 3-35 kit. After instillation, I noticed the equalizer between my center and rear wheel is way out of alignment on both sides. After searching and searching online, I found out that the hangers seem to now have been installed without the proper separation.
To my understanding, the first 2 hangers should be 30.5" apart, then at the center wheel they should be 35" apart and the rear wheel they should be 30.5". so it would show 30.5", 35", 30.5"
Mine are 30.5", 33.5", 30.5"
I've reached out to Forrest River for assistance. My only guess is that I will have to replace the 2 rear hangers on each side and have them welded with the proper separation.
Thoughts?
