Originally Posted by NMWildcat
Return air routed through 14" x 14" hole a/c and ceiling attachment (air distributor) is mounted to.
I was answering AquaMan's comment about what would be required to make the second add on A/C a true ducted system.
True, the easiest way is to get the "bottom dump" type A/C unit & just hook to the existing pre-wire. But, part of the OP's original post was noise level of the bottom dump opposed to the ducted system and his quest for possible quieter options.
2014 Prime Time Sanibel 3250
